no start L245DT
/ no start L245DT #1
Tims1185
VA
Kubota L245dt
I have checked for and have fuel to injection pump, but find that when I remove tubes to injectors I have no fuel delivery. Is it safe to use carb cleaner directly into air intake, to see if it will fire? Also is the pump a problem to remove if that's what I find it to be, do I need a dealer?
/ no start L245DT #2
Did you bleed it at the fuel filter and at the fuel pump? I have ran out of fuel several times in the 30 + years and never have had to do more. No white smoke out of exhaust means no fuel. I would put some pressure to the fuel tank and make sure you are getting a good flow of fuel.
/ no start L245DT
I'll try some pressure. Good idea, maybe plugged filter.:)
KUBOTA 4 PRONG BALE SPEAR (A62130)
KUBOTA 4 PRONG...
New Holland 3930 (A60462)
New Holland 3930...
18" EXCAVATOR BUCKET (A62131)
18" EXCAVATOR...
2023 HANGCHA CPYD30-XW71F STRAIGHT MAST FORKLIFT (A62129)
2023 HANGCHA...
UNUSED INDUSTRIAS AMERICA 170-7' SCRAPE BLADE (A62130)
UNUSED INDUSTRIAS...
2018 Forest River Cherokee Trailer, VIN # 4X4FCKB26JX130699 (A61166)
2018 Forest River...
