So I goofed
/ So I goofed #1
dagofast
Gaines Mi
Bx1500
I noticed some oil dripping on the ground last winter after I plowed the drive way. It was my axle pivot bolt seals. Last week I finally replaced the seals, bushings, back up seals, bolt, and even the nut. Didn't realize the when I lowered the steering cylinder down I had removed the steering lines from a bracket that keeps them away from the flywheel. So yesterday after cutting an acre and a half of lawn I noticed plumes of white smoke coming from under the tractor. I knew exactly what it was. Took the cover off and yep, both hoses have a small cut and spraying fluid on the muffler. Two new lines $64. Only thing I need to know is if there is a bleeding procedure?
/ So I goofed #2
I don't know the procedure definitely, but I bet you just keep the fluid topped up and crank the wheel back and forth just like with a car.
ac
/ So I goofed #3
Welcome to TBN. That's quite an introduction. :) You're a brave man to admit to such abuse in your first post. :D
/ So I goofed #4
If you have a loader on the front, use it to lift the front axle off the ground ... then with the engine running turn the wheel left & right lock to lock a half dozen times or so...
/ So I goofed
@Kenny, thats a great idea but i don't have a loader. @raydakub, you know sometimes **** happens, but move on right? You shoulda seen the smoke clouds it was making!
/ So I goofed #6
That's two laws of the forum, set in stone, that you've already broken.
1. Admit that you messed up in your first post. (wait until at least the third) :)
2. Didn't take a picture of the smoke signals you were sending up. Impressive???? :)
Man, I thought stuff like that only happened to me. It's good to know that I have a friend and companion.
/ So I goofed
Wow! I guess im just breaking stuff left and right! lol
/ So I goofed
Just figuring out how to post pics
/ So I goofed #9
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=321201"/>
LOL! Cars outside, tractor inside just as it should be!
Sent from my iPad using TractorByNet
/ So I goofed
Well, considering I paid more for the Kubota than the Tahoe.....:laughing:
/ So I goofed
Just an update to finish, I bought 2 new power steering lines from my local Kubota dealer. $30 each. Bought some UDT fluid. It took a total of an hour and 20 to replace both lines and that includes figuring out I put them on backwards at first:duh:. (steer left, wheels go right). It blead out with no problem and I only had to add a pint of fluid.
/ So I goofed #12
Your going to fit in fine here!.. Welcome to TBN
James K0UA
/ So I goofed #13
Brother? Is that you?
:) welcome!
2021 John Deere 1023E Tractor Loader (A63116)
2021 John Deere...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
Arrow Quip EF10 Top Bow No Sides (A64047)
Arrow Quip EF10...
2024 High Country Cargo 6x12 Enclosed Trailer, VIN#7FWBE1217R1035595 (A61166)
2024 High Country...
2016 Chevrolet Cruze Sedan (A61569)
2016 Chevrolet...
2019 International DuraStar 4300 Service Truck, VIN # 1HTMMMMN1KH714519 (A61165)
2019 International...
