So I goofed
/ So I goofed #1
dagofast
Gaines Mi
Bx1500
I noticed some oil dripping on the ground last winter after I plowed the drive way. It was my axle pivot bolt seals. Last week I finally replaced the seals, bushings, back up seals, bolt, and even the nut. Didn't realize the when I lowered the steering cylinder down I had removed the steering lines from a bracket that keeps them away from the flywheel. So yesterday after cutting an acre and a half of lawn I noticed plumes of white smoke coming from under the tractor. I knew exactly what it was. Took the cover off and yep, both hoses have a small cut and spraying fluid on the muffler. Two new lines $64. Only thing I need to know is if there is a bleeding procedure?
/ So I goofed #2
I don't know the procedure definitely, but I bet you just keep the fluid topped up and crank the wheel back and forth just like with a car.
ac
/ So I goofed #3
Welcome to TBN. That's quite an introduction. :) You're a brave man to admit to such abuse in your first post. :D
/ So I goofed #4
If you have a loader on the front, use it to lift the front axle off the ground ... then with the engine running turn the wheel left & right lock to lock a half dozen times or so...
/ So I goofed
@Kenny, thats a great idea but i don't have a loader. @raydakub, you know sometimes **** happens, but move on right? You shoulda seen the smoke clouds it was making!
/ So I goofed #6
That's two laws of the forum, set in stone, that you've already broken.
1. Admit that you messed up in your first post. (wait until at least the third) :)
2. Didn't take a picture of the smoke signals you were sending up. Impressive???? :)
Man, I thought stuff like that only happened to me. It's good to know that I have a friend and companion.
/ So I goofed
Wow! I guess im just breaking stuff left and right! lol
/ So I goofed
Just figuring out how to post pics
/ So I goofed #9
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=321201"/>
LOL! Cars outside, tractor inside just as it should be!
Sent from my iPad using TractorByNet
/ So I goofed
Well, considering I paid more for the Kubota than the Tahoe.....:laughing:
/ So I goofed
Just an update to finish, I bought 2 new power steering lines from my local Kubota dealer. $30 each. Bought some UDT fluid. It took a total of an hour and 20 to replace both lines and that includes figuring out I put them on backwards at first:duh:. (steer left, wheels go right). It blead out with no problem and I only had to add a pint of fluid.
/ So I goofed #12
Your going to fit in fine here!.. Welcome to TBN
James K0UA
/ So I goofed #13
Brother? Is that you?
:) welcome!
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
2021 ASV 75HD Skid Steer (A64047)
2021 ASV 75HD Skid...
UNUSED SDLANCH BI-PARTING WROUGHT IRON GATE (A62131)
UNUSED SDLANCH...
UNUSED IRMC HIGH-END ELECTRIC MASSAGE CHAIR (A62131)
UNUSED IRMC...
30 Yard Dumper (A61166)
30 Yard Dumper...
2015 Bobcat T770 Compact Track Loader (A64047)
2015 Bobcat T770...
