Underhood temps of my BX
   / Underhood temps of my BX #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I've been mowing with my BX 2350 a lot lately and as usual, the temp gauge doesn't hit the red, but it does get close. I know this subject has been talked about a lot but I bought one of those point and shoot thermometers last year and tried it out on the BX. I shot the water neck where the radiator hose hooks on, about 190, various places around the engine block, between 160 and 190, even the exhaust manifold and the block near it doesn't get much above 210. Don't touch the muffler though, it gets over 300 degrees.
   / Underhood temps of my BX #2
Maybe talk to the salesman and see if he will cover it under warranty. If not go directly to the sales manager
Nothing to really turn in for warranty work. There are a lot of BX owners that worry when there temp gauge gets close to the red zone, I'm just posting this to show them some of the temps and to say in my opinion, it isn't overheating.
   / Underhood temps of my BX #4
Seems to me there is something to turn in......your temp. gauge. I would definitely have them replace the temp. gauge or it will become a gauge that you really don't pay attention to and then one day it might be overheating, and well....you know the rest! Just a suggestion. :smurf:
   / Underhood temps of my BX #5
Thanks for the temps. So far with about 20 hours on my 2360 I have noticed it go about 3/4 of the way up on the temp gauge while mowing. When I turn the deck off it will go back down to around halfway. After searching some threads, I am comfortable with it. Maybe next time I am mowing I will measure the temps with a thermal gun too.
I notice on my RTV, which has the same motor as the 2360 (just set up different) runs higher than half way too when it is hot out and I've been running it a lot. I just accept that as normal. The dealer says its fine.
   / Underhood temps of my BX #6
On my BX1500 I have just the opposite problem, the temp gauge reads low. It just barely comes up off the bottom.
I also took some temp readings with an infrared thermometer and it showed the same readings that you got.
   / Underhood temps of my BX #7
The B7800 I had was that way. Just a little past the cold mark.
   / Underhood temps of my BX #8
My 2200 always read right at mid range, and recently was running a little high. The gentleman who bought my LA211 last weekend showed me my rad was plugged up behind the battery. I cleaned that out and I'm sure it will run cooler next mow.
   / Underhood temps of my BX #9
Try blowing out the rad with a air gun, and see if that helps. I do that after every mow, and my gauge reads very consistent. I find waxing it helps it run cooler as well, but that may just be me. LOL
   / Underhood temps of my BX #10
You wax your radiator???????? I guess I'll just sell my tractor... :D
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
2016 Chevrolet Caprice Sedan (A55758)
2016 Chevrolet...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
DR. CHIPPER PORTABLE WOOD CHIPPER (A54756)
DR. CHIPPER...
ANTIQUE OIL PUMP (A54756)
ANTIQUE OIL PUMP...
2014 Jacobsen AR3 Commercial Mower (A55787)
2014 Jacobsen AR3...
