hydraulic steering valve?
/ hydraulic steering valve? #1
allen6634
hawesville
600 ford
i have been cleaning out my building, i run accross a dash pannel off a yale fork truck, the steering wheel is attached to some sort of pump/motor/ valve, i don't know how this was plumed , and i can't find any info on this thing, i am assuming that this was the steering valve, because the steering wheel was bolted to it, this thing only has two ports, so i am more lost on how this thing worked , i have been wanting to make my tractor power steering, so i am hoping that this thig is a steering valve. i would realy appreceate any advice on this matter.:confused2:
/ hydraulic steering valve? #2
Post a picture and the info you can find on the pump.
i am including the photos of the thing i tryed to get a pic of all angles, i took one with the numbers on the thing. i didn't see any name on this
/ hydraulic steering valve? #4
I believe it is a torque generator.
well i guess this isn't going to help with my power steering project huh
/ hydraulic steering valve? #6
Have you thought about a cheap junkyard power steering pump from a car or truck?
I believe the pressure is about 1000 to 1500 psi.
My Power-Trac machine is articulated, and steered by two cyl and a hyd steering unit.
If you can't use it, just clean it up and sell it. It probably still has valve to someone.
I believe the presure is about 1000 to 1500 psi.
yes i have, actually i have already bought one, i was planing on using a rack off a mustang, and a pump off a neon, i bought them took the home was putting them up when i found that fork lift thing, and thought that is would be easier to run some hose than it will be to build a shaft.
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
2018 Lincoln MKT Town Car AWD SUV (A61574)
2018 Lincoln MKT...
10' Rotary Hoe (A64126)
10' Rotary Hoe...
2014 Chevrolet Sonic Sedan (A61574)
2014 Chevrolet...
2011 Ford Expedition SUV (A61574)
2011 Ford...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
