4720 fuel gauge not working
/ 4720 fuel gauge not working #1
MikeF
Maryland
JD 3039R cab
Okay, So I got in my 4720 today and the fuel gauge is not working...... also when I start it the screen says long8 then short d (what the heck does this mean) ??????
Please help
Mike
/ 4720 fuel gauge not working #2
Is this a new tractor? If it is I would put it on a list of things for the dealer to fix.
no this is not new and it just started doing it
Well, I found the long short info in the manual, and that is not a problem and has nothing to do with the fuel gauge. The fuel gauge sometimes works and sometimes does not, mostly not. If anyone has had problems with one of these please let me know what fixed it.
Thank You
/ 4720 fuel gauge not working #5
I had a 2007 4320 (bought new) and the gauge was not accurate from new so the sending unit was replaced under warranty. The new sending unit seemed slightly better accuracy wise but not by much.
I now have a 2010 4320 (bought new) and the fuel gauge accuracy seemed fairly decent until it went on the blink. The sending unit was replaced and it works but not so accurate. For example, when the tank is full the gauge reads little over 3/4 full. When the "low fuel" indicator comes on the tank is really almost half full. I can live with this as long as it is consistently the same.
Thanks for the info sunnyside, I would not care but I am getting rid of the machine and need it to work. I talked to local dealer and he feels it is the sender as well and gave me advise on how to do the job. the part is $171.79 ugh
/ 4720 fuel gauge not working #7
Seems this is not an uncommon problem. I own two John Deere, and both have had sending units replaced under warranty
//greg//
/ 4720 fuel gauge not working #8
My 4520 was doing same thing, just changed sender and works great now.
Luc
//greg//
/ 4720 fuel gauge not working #10
Looks to be LVA17266
/ 4720 fuel gauge not working #11
I suggest first determining if in fact it is the sender. At least on my tractor, maybe the dealer or another member can validate this for your tractor, you disconnect the 2 wires at the sender and touch them together and the gauge should go to full. You can do this test with the tractor off and the key in the run position.
Using the part number Beenthere LVA17266 supplied at greenfarmparts.com it is $70.68.
2012 FREIGHTLINER CASCADIA 125 6X4 TANDEM  SLEEPER TRUCK TRACTOR (A69167)
2012 FREIGHTLINER...
2027 . 500k BTU Wellhead  Heaters (A67714)
2027 . 500k BTU...
2025 JMR 38in Hydraulic Rock Grapple Bucket Mini Skid Steer Attachment (A66734)
2025 JMR 38in...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2004 NiftyLift TM50 HGE 50ft Towable Articulating Boom Lift (A66734)
2004 NiftyLift...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
