Loader Loader Lights Dissapointment Help
   / Loader Lights Dissapointment Help #11
The reason they wired it this way , may be to prevent overloading the charging system.
Dave
I believe you are right. If it were me, I'd rewire it, but keep an eye on it to make sure you do not drain the battery running all the lights at once.
I'm looking forward to hearing what/how your dealer responds to this conundrum! The situation does not make a great deal of sense! Most definitely not an "optional" feature that's worth a $1,000!! :eek:
AKfish
I will talk to him on Monday and see what he says. I agree that for the price it's definitely not worth the $1000
I have a theory to the the reason the head lights don't work at the same time as the work lights... I may be 100% wrong.
They do not work together so you can not accidentally blind oncoming traffic with the work lights while driving on the road.
True, I could see that but common sense says to shut them off during road travel plus they do have their own high beams and low beams so they should be adjusted like headlights to avoid blinding oncoming drivers.
Commom sense tells me that they should not come on with the headlights in "driving" mode, but they should all come on in "work" mode.
Yes but they are a driving light to assist the headlights when having a loader attached but the way they have it set up is when the loader is attached you use them instead. They are automotive style headlights so they should be ok and if aimed properly shouldn't affect the driver.
Dave
It does come with a 90 amp alternator with the possibility of upgrading to the 120 amp so there should be lots of power to use all the lights.
If the dealer doesn't do something then I will end up doing my own rewire (try and figure out how to bypass the switch that shuts the headlights off when the loader lights are on.)
   / Loader Lights Dissapointment Help #13
Good lesson here. Whenever we have something done, we should be very explicit as to our expectations. Even if it seems like common sense to us, it is always better to assume our expectations may not seem like common sense to those doing the work for us.
   / Loader Lights Dissapointment Help #14
That's the way the optional cab lights work on my M. There's 4 roof mount lights - front and back - they are all "ON" when the light selector switch is on "bright".
AKfish
AKfish
My roof lights come on with the light switch set to the work position, I got:
-Off,
-Flashers (both self explanatory),
-Road lights (flashers on and headlights on and in this case I pick either tractor OR loader lights to come on, both have high and low beam.),
-Work lights (all 4 roof lights on and headlights on, again I pick tractor OR loader lights and both have high beam and low beam again.)
Talked to my dealer today and he said its so the operator doesn't forget to turn it off and blind oncoming drivers on the road, but he knows a lot of farmers who have that feature and bypass it so both sets of lights do come on.
I told him that wasn't an issue with me so he sent me to talk to the shop Forman who said this was the first install of that type that he's done so he has to look in the install manual and will get back to me.
   / Loader Lights Dissapointment Help #17
They should have given you the install manual at delivery.
I talked to the head mechanic today and he said thy John Deere rigged the tractor that way on purpose cause something about the headlights reflecting off of the loader and the reflected beam overheating things and causing malfunctions. Personally I think that is the stupidest excuse if I ever heard one cause if that was the case all tractors with FEL's would have no headlights on them.
So cause I want it to perform differently it will cost me another $600 for them to come out with some parts and do a field repair to make it work how I wanted, I'm just a little pissed about that, spend $1000 for a part installed, it doesn't work like I thought it would (and they didn't tell me I would lose my headlights when using the loader lights.) so now I have to spend another $600 so my $1000 lights will work how I expected them to work from day one.
Finally got a tech out here for the lights, I couldn't believe how easy the fix was, it took us 1/2 hour to figure it out and 2 mins to fix. All it took was jumping two sets of wires and now headlights work like normal and the loaders lights turn on and off with the switch and stay separate from the headlights.
If anyone else has these lights or is thinking about getting these lights let me know and I will post pics of the wires jumped.
Now I have to wait and see what the service call will cost me (Think there is a discount for me showing the tech what the solution was? Lol)
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2025 Auger Skid Steer Attachment (A53421)
2025 Auger Skid...
Estate Equipment Auction 9/27/2025
Estate Equipment...
2017 Gravely Pro-Turn 460 60in Zero Turn Commercial Mower (A55973)
2017 Gravely...
2015 Ford F-350 4x4 Pickup Truck (A55852)
2015 Ford F-350...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
