Pressure washer purchase
/ Pressure washer purchase #1
KENSFM
Gold Member
MA
JD 2210 JD318 JD332
I am looking to purchase a new gas pressure washer for home use. I would like to spend $300-$400. Any suggestions?
Thanks, Ken :)
/ Pressure washer purchase #3
Thanks, Ken :)
Wal-Mart has the Karcher with Honda GC engine for $279 in sale (regular $379) I'm waiting for the "RollBack"
/ Pressure washer purchase #4
My suggestion, spend more money.
Pressure is cheap. 1000 psi will work but 1500 will be better. Any more and you will want to use 2 hands on the wand. But gallons per minute is what makes pressure washers earn their spot in the garage and that is what drives up the cost. Less than 1.5 gpm will leave you wishing for more, at least it does for me. For me, 2.5 gpm and 1500 psi is the minimum but that is more than your price.
/ Pressure washer purchase #5
What ever you buy try to buy one with a cat piston pump, They run for ever.
/ Pressure washer purchase #6
Thanks, Ken :)
Whichever PW you buy, make sure you can buy replacement pump parts. Don't buy a Sears/Craftsman, as they do not have any replacement parts for the pump. They only sell a replacement pump and it's almost the cost of a new PW. I can't remember where I bought mine, but I'll check tomorrow. It's been good to me for the last 9-10 years. I had to replace the pump seals last year at a cost of $40 dollars for the seal kit, but that's not bad for 10 years of service.
/ Pressure washer purchase #7
I bought a GENERAC version I think 3500PSI at 3 GMP w a 6 or so HP motor, was 379 last spring. Works well & happy with purchase, they sold one bigger but was like 600 bucks.
Mark
/ Pressure washer purchase #8
Okay, I bought mine from Northern Tool and it is a North Star with a Honda engine.
/ Pressure washer purchase #9
Link? Cant find one with a Honda that cheap..
/ Pressure washer purchase #11
/ Pressure washer purchase #16
Not so fast!!
We get gouged big time in ALL things taxed.
Even though some goods may be less $$ overall it costs WAY more to live here
Ok, I'm moving to the border ;)
/ Pressure washer purchase #17
I have to agree here. I worked on a lot of pressure washers. I built my own with a Cat pump and Generac 5.5 hp
horizontal OHV engine. Stay away from axial pumps and vertical shafts if you can afford to. Always look for a Brass
head assembly and stainless valves. Karcher has a lot of plastic in it.
/ Pressure washer purchase #18
Another thing you should consider is heat. Cold water works OK for some things but not so well for others.
I picked up an OLD L&A Crusader with a kerosene burner heater about 10 years ago and replaced the bad pump in it.
The total investment was about $400 for a 3.5 gpm, 2500 psi, heated unit. It still works great!!
/ Pressure washer purchase #19
I picked up a 2700 psi Troy Built from Lowes. Very nice. Has plenty of pressure and volume for the average homeowner. It was about $279 earlier this spring.
/ Pressure washer purchase #20
I went to electric washers and I am never going back to gas!
Northern tool sells some excellent electric models (commercial grade) for about $500. They seem to last very long time with no trouble. My buddy has his for more than 10 years with 0 trouble, mounted inside his garage right next to the overhead door, hard wired with lights like on-off switch. He has spring loaded hose rail with 50ft hose. Real nice.
Northern tool also has refurbished units on eBay for less.
2025 Quick Hitch Skid Steer Attachment (A61572)
2025 Quick Hitch...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2018 John Deere Z950M Zero Turn (A63116)
2018 John Deere...
12ft S/A Utility Trailer (A61574)
12ft S/A Utility...
2005 John Deere 310SG Backhoe (A64047)
2005 John Deere...
Electric Tricycle (A64194)
Electric Tricycle...
