Help with new ym226D purchase
/ Help with new ym226D purchase #1
Smoody
South Carolina
YM226D
Hi everyone,
I went out and bought another yanmar this weekend, got a good deal on it but it needs a few things repaired.
I attached the pictures for reference and hoping someone can give me some advice / experience with this.
Tractor is a YM226D with Yanmar FL800 loader, US model with power steering.
1. It has a pretty steady hydraulic leak in rear where the entire rear section of tractor connects to the transmission area, it has 6 #7 bolts holding the rear to the mid section? (I guess I'm describing it right). It appears the tractor needs to be split back there to replace a seal but I do not know what the part is called, anyone help me out with what the proper repair is called for that area?
second thing, I believe I can figure out but wanted to throw it out here for any hints on where to begin, guess it could be as simple as bad ignition switch.
1. Tractor does not start with the key, the dash lights illuminate but when turned to start nothing, it will fire right up jumping solenoid to starter.
Starting it this way I leave the key turned to the on position and the "lighting bolt" dash light stays on??
I got to decide if this will replace my YM2210, that's the hardest part :eek:
/ Help with new ym226D purchase #2
Check the Hyd. Vent. Sould be a U shape tube under the seat. That would be a good place to start... On your Solenoid use a test light on the Terminals and check for power to it when you turn the key on. My bet it's bad
/ Help with new ym226D purchase #3
If I am understanding correctly about your leak I don't believe it has anything to do with a seal leak. Everything in that area should be filled with transmission fluid. Looks like a gasket leak to me. Have you tried snugging up on the bolts just making sure they are not a little loose? If the bolts are not loose I would probably shop around for some kind of a sealer, clean the area, apply the sealer and see what happens.
Need to take a voltmeter and see if you are getting voltage to the small wire on the solenoid when you turn the key to the crank position. If not, trouble shooting the system to figure out why. Good starting point might be to take a look at all the fuses. Rotate them around in the holder. These old fuse boxes are bad about loosing a good contact sometimes. I know from experience. That lightning bolt staying on sometimes was caused by a loose fuse on mine. Roll your fuses around with it running and watch the light. I can post you a wiring diagram for it if it would help.
Winston, you are correct, I meant gasket..i thought about draining the fluid out and cleaning and sealing that around that area externally, as i believe you are suggesting?
The guy did have the hydro level WAY to high, taking the dipstick off the fluid level is above the gears, and about 3 inches above the "level indicator area" of the dipstick..
It looks like a pretty big project unhooking everything including the loader to pull that area apart and replace the gasket :eek:
The starting issue was the battery, it checked at 12.06 Volts, its enough to start it by jumping the solenoid, but not enough juice through the switch, put my battery from my 2210 in it and it fired right up, the charging light does not go out though, so I checked the battery with tractor running and it is not charging..
so which would it be, voltage regulator or alternator?
/ Help with new ym226D purchase #5
The 226 has the little dynamo like mine. Not much to them and little to go wrong other than bearings. You can check the voltage on the two wires coming off it with a voltage meter set on ac volts. It should read 18 maybe more ac volts with the engine running 1500 or so. If you have that then make sure that voltage is getting to the regulator. If so, then see what dc voltage is coming out of the regulator. If not more than battery voltage it is probably bad.
Does anyone know what the part number is for that gasket? I don't see it on Hoye.
a parts manual in pdf form would make my day,,if anyone has it
Also, as a temporary fix, any recommendation on what the best product/sealant is for use on the exterior to seal that crack?
Fluid drips even when the tractor is parked. just a steady drip every 20 or so seconds.
Oh and if anyone is interested in a YM2210 with allied Loader let me know
/ Help with new ym226D purchase #8
Click on the first item on this google page and you can download your parts manual. lozeman yanmar 220 - Google Search
If your gasket is reference #31 on figure 40 of the parts manual (194420-24120) here is the gasket. http://www.hoyetractor.com/mm5/merchant.mvc? I may be in the wrong place, you can determine that.
Well copying that part number didn't work. You can just type in that part number in the Hoyes part "search" field and it will bring it up for you.
/ Help with new ym226D purchase #9
Just curious, I notice the parts manual doesn't shown power steering. Is your power steering a cylinder assist type? Maybe added later? Or is it the factory gearbox power steering?
It is a cylinder, so likely added later..I have no way of knowing. works nice though
Thanks for the parts manual link! and yes that is the exact gasket that is leaking...any chance you got info on how to make that repair?
Now what about sealing it on the outside with a sealer? bad idea?
/ Help with new ym226D purchase #11
I don't know whether it is a bad idea or not. I do know I would try it before taking all that apart. I am not familiar with all the different sealants. Maybe someone at the auto parts counter could give good advice on that? Did you double check the bolts just to make sure they hadn't loosened a little?
I did check the bolts, hard to get to but they feel tight to me..I would have to remove some things to get good torque on them..
That gasket is a $4 part..haha but that Labor is likely a whole day...
/ Help with new ym226D purchase #13
Sealing from the outside wont hurt anythng.
I would use RTV black or Grey (my personal preference) and use carb cleaner or brake clean and spray the area clean after you have drained the fluid and it stops dripping. I would spray clean then let dry then spray and wipe clean then spray clean one more time. If its stopped dripping, go around the mating area of the gasket with a thin bead that you hand spread to above the fluid line on the split surfaces. It wont look pretty but should stop a leak, for a period of time.
Thanks clemsonfor.
One other thing for conversation, I plan to drain and replace the fluid and clean hydro screen this weekend. The tractor hesitates after you put it in gear before it starts moving, like a 2-3 second delay, but all ranges and gears work, the front loader isn't really fast either, my guess is the internal screen is partially plugged up, on the right track with that assumption?
/ Help with new ym226D purchase #15
From what i have read on here, i think a dirty filter or dirty fluid will cause a hesitation, but i am not saying that that will fix your problem.
I was in The county this weekend at the farm property. I spent most of saturday on the tractor finishmowing and bushhogging. Then a few hours sunday mourning before we hit the road.
/ Help with new ym226D purchase #16
One thing i just thought of, is taht if this is on the bottom of the tractor where the trans meets the bell housing or something like that this will only last as long as the silicone. I cut so much tall grass and junk like sappling and briars and stuff that the constant rubbing of the under belly would wear the silicone off in probably a day of mowing, which wont do you anygood. If the area is kind of hidden in a recess you may get a bit more time out of the patch.
/ Help with new ym226D purchase #17
if its fairly clean and dry you might be suprised how long it will last, I like the black,its not under press so you might just luck out,did u say it was only a drip every few seconds......give it a go,might just seal it
keep us posted
nice looking 226d
From CT
I will drain and clean the area this weekend and try a sealer, I will post back my results.
Clemsonfor, why don't you upgrade to my ym2210? you can come check it out since you have property here.
/ Help with new ym226D purchase #19
I dont have the cash to do it. Well i do but i dont need to spend it. I would love to have the extra power the trans and the loader!!! But i have been getting along fine with mine so i guess i will keep on keeping on.
/ Help with new ym226D purchase #20
If I was going to try and seal it w/o splitting it I would drain it and clean it super good with brakekleen and air and make sure all the bolts were tight as has been mentioned and use high temp gray just because that's what I have on hand always.
Let it sit overnite with the cap off so there isn't any pressure. I have sealed a/c and radiators with glue and we usually put them under a vacuum and that theoretically pulls the sealer or glue into the crack whatever but it does work. Good luck on the nice new tractor!
I suppose if that fails it could be drained and split a fraction of an inch and sealer put in place and tightened all back up in that case I would use anaerobic. just my .002
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
7ft Fork Extensions (A65579)
7ft Fork...
121A (A63745)
121A (A63745)
20ft Driveway Gates (A65579)
20ft Driveway...
213086 (A64276)
213086 (A64276)
