Another Bridge Thread
/ Another Bridge Thread #1
ballegre
NC
Kubota L3010 2000
Hi All,
I've been designing a bridge to hold my tractor using information I collected from here. The overall design is 12ft long with beams 5ft apart matching the wheel width on the tractor. The beams are to be 2 x laminated and bolted 12ft long, 2x12s which will give me a 12ft long 4x12 beam on each side. According to this web site http://www.forestryforum.com/members/donp/beamclcNDS2.htm, should hold at least 3250 lbs at each point for a total of 13,000 lbs using No 2 loblolly pine.
My kubota L3010 with cutter and fully loaded front loader should never exceed this lb limit. However, the devil is in the details.
My problem that I am having is due to the way I want to set the bridge beams on the concrete columns.
I'm designing to avoid having wood touch dirt to prevent rot (and yes I'm using pressure treated wood). So the colums will be at grade (grade slopes down toward the small creek) and, as you can see from the diagram, I want to set the beams on the columns and cut out a short 2 ft ramps in the beam to get on and off the bridge.
So my question, to anyone who has an opinion, is by cutting out the ramps on the beam, have I weakened the entire beam (I assume to the 7" depth that I have indicated)??
Of course I would never hold anyone liable for any information they provide and release you from any and all legal responsibilities for any opinions you offer :)
/ Another Bridge Thread #2
I'm not an engineer but it doesn't look like a good idea to me. How about building a separate ramp to the bridge?
/ Another Bridge Thread #3
I would build a seperate ramp and dig out your approach. Backfill with crusher run gravel and compact it. This will keep water away from the wood. Make sure you have a swale, ditch, or curtain drain to keep water away from the bridge approach a few feet before the crusher run
/ Another Bridge Thread #4
Yes I have a big problem with that. You need to recalculate everything based on 7 inch beam, not 12. The compression strength is at 7 due to the cut of slope regardless what size beam you are using. I would move the start of the slope at thee end of the concrete column to get the 12 inch beam strength you wanted. I know you wanted a nice smooth ramp up - for tractor, but you are better off using crusher run for the ramp to have a smooth ramp up, but still allow for drainage.
Wanted to avoid a separate ramp because of the extra work. I can do it if it's necessary.
A 12 inch deep approach seemed difficult to me and I didn't even think of the drainage issue (thanks!) which makes it even more difficult.
/ Another Bridge Thread #7
If you have a loader this should only take a day. Use it to truck in your materials. Consider renting a skid steer or full size backhoe for a weekend to help.
I did calculate at 7 inches and it does not hold. So I won't be going with this design.
/ Another Bridge Thread #9
I would do this:
Bruce
/ Another Bridge Thread #11
My Kubota L3010 with cutter and fully loaded front loader should never exceed this lb limit.
What happens when you decide to upgrade to a bigger tractor five or ten years from now?
Personally, I would not design for "should never exceed". I would go with a minimum of 2x or 3x capacity.
Also, are you considering the weight of the decking material?
Does the creek flood? A couple of miles down the road, a guy put in some nice piers and set a flat bed truck trailer on it for a bridge. He built up some nice approaches with creek rock. The first good gully washer washed out the approaches and moved the deck a couple of feet :( The next big storm washed it out entirely. We can now see the end of the buried deck a couple of hundred feet downstream with about 5' of it sticking out. He gave up on the project.
/ Another Bridge Thread #12
Hi All,
Could you use 16 foot 2x12's. That would give you the two feet overhang ( each end) on your piers for the ramp.
/ Another Bridge Thread #13
Get an old 40' single wide, rip off the top and use the frame as the bridge.
/ Another Bridge Thread #15
I second the over-building. You never know if you'll need/want to take something heavier across. Also wood will degrade and you may get a sudden failure with you on it being close to the load limit. Most road bridges are built to 2-3x the rated load to accomidate unforseen issues and degridation. I'd rather have it crack or bend rather than ride it down suddenly.
/ Another Bridge Thread #17
Most of your designs are not going to fail with a point load on the center of the beam. everyone likes to point to this relatively simple equation to get their design strength. Most people forget about adding in the weight of the decking, or the dynamic loading of their equipment. usually though, the support will fail at the connection points first. The shear stress or crushing force at the supports is what mostly dicates any beam design, usually followed closely by torsional loading due to a slenderness ratio that should not be exceeded to provide a safety factor. It has been a long time since I have been in my structures class but thats vaguely what I dredged up out of my memory.
Also, an acceptable level of deflection can also be a governing equation. A beam might hold a load while deflecting 6" or more but thats not very confidence inspiring nor does it lend well to having anything else attached to it. There is a reason engineers are required to be licensed. I'm not saying that building a bridge is impossible nor does it require an engineer to design/construct a simple crossing. Knowing how to correctly design things takes more than just picking a single equation.
/ Another Bridge Thread #18
You need to add a 4x safety factor.
You probably need a buildup of five 2x12s
Pre drill your bolt holes and then when you put it all together use some construction adhesive to glue the 2x12s to each other.
If you have access to some 1/4" or 3/16 plate you can sandwich your wood around it an bolt the assembly together. It's called a Flitch plate round this part of the country.
For the approaches you could build some ramps out of 2x6. They would be semi sacrificial.
You could also get some timbers to lay in front of the bridge to form a ramp. A 8x8 then 6x6 then 4x4.
/ Another Bridge Thread #19
Be sure you inquire about needing any permits to build this bridge. I think permits would only be required based upon the size of the structure, if it were crossing a stream & if the stream had fish etc, etc. Your county planning/building dept should be able to answer this question. I know how distasteful it is to call a gov agency and let them know what your plans are but its far better to know in the beginning then have them stop the project half way thru.
/ Another Bridge Thread #20
One thing to remember is that not all pressure treated wood is rated for ground contact. As dirt collects on top of the cement between the wood it will start to rot much quicker.
2014 Freightliner M2 106 Bucket Truck, VIN # 1FVACXDT2EHFU7070 (A61165)
2014 Freightliner...
2024 John Deere 8R 370 Tractor (A63109)
2024 John Deere 8R...
2021 Soil Warrior 4500 (A63116)
2021 Soil Warrior...
2010 Acura MDX AWD SUV (A61569)
2010 Acura MDX AWD...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
UNUSED WOLVERINE DB-15-84W 84" HYD PUSHER BLADE (A62131)
UNUSED WOLVERINE...
