5065e 3R/9F Sync Shuttle question
/ 5065e 3R/9F Sync Shuttle question #1
Rmd8136
Gold Member
Ft mill, sc
Deere 5065e MFWD
Test drove a 5065e today. In "A" range the 2-R clutch less shuttle shift worked flawlessly. In "B" range it would not engage (latch in slot) and if forced gears would grind without clutch. How is it supposed to operate? I read on tractordata.com that shuttle shifts are available in all 3 ranges. Shuttle means no clutch, right? Is this an easy adjustment?
/ 5065e 3R/9F Sync Shuttle question #3
No, on a shuttle shift it needs to be clutched to change gears.
Ok. If the sync-shuttle allows forward shifting on the fly, using the clutch , what function is the shuttle performing . The sync reverser transmission description says shuttle shift only between 2-R; must stop to change to higher forward gear (like 1-3). I guess the shuttle handles synchronization only between 2-R. The sync shuttle has the additional benefits of up shifting without stopping using clutch . Basically you must use clutch for all shifts but don't need to stop unless changing ranges . Can anyone explain the no grinding , smooth as butter , shifts from 2-R in A range? Gears turning so slow they would not grind?
/ 5065e 3R/9F Sync Shuttle question #5
The slower that the gears are spinning the less likelihood of grinding gears on a shift.
So if the sync shuttle allows for up-shifting w/o stopping (like 1 to 2 to 3), compared to the sync-reverser which does not (only between 2-R), the shuttle must be performing a synchronization that is unique to rolling in one direction (say forward) and being able to move gear selector to reverse gear w/o grinding? I would think if you must depress clutch anyway when shuttle shifting between 2-R, there is no way it could grind anyway. I am just a little confused to exactly what the shuttle is doing when comparing the sync reverser (which requires you to stop to change to a higher forward gear) to the sync shuttle (which lets you "shift on-the -go" while moving forward?
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
24in John Deere Rims (A63116)
24in John Deere...
2019 ISUZU MPR HD 18' BOX REEFER TRUCK (A62130)
2019 ISUZU MPR HD...
PC 4500 Pallet Jack (A61166)
PC 4500 Pallet...
KMC 216-18' HEAVY DUTY ROTOTILLER (A62130)
KMC 216-18' HEAVY...
2014 Takeuchi TB260 Midi Excavator (A61567)
2014 Takeuchi...
