John Deere 350 sickle mower
/ John Deere 350 sickle mower #1
bledsoe73
Miami, Ok
Ford 7700
I have a john deere 350 9' sickle mower and I put a new belt on it. The is loose and I need to know how to ajust it. Also the spring that levels the blade when the blade is down it will not lay flat on the graund the end is up about 4" how can this be ajusted down ? Any help would be appreciated. Thanks.
/ John Deere 350 sickle mower #3
You should be able to adjust the float of the blade and get it to lay down flatter by adding links in the chain that runs thru the middle of the cutterbar spring. Lift-raise the cutterbar up to take the tension off the spring and then add links.
Did you have to move the pulley to get the old belt off?
AKfish
/ John Deere 350 sickle mower #4
There is a bolt for adjusting belt tension. It is located at the left and low. A owners manual would be a good investment. Ken Sweet
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused 2025 CFG QK18R Mini Excavator (A61166)
New/Unused 2025...
JOHN DEERE 4440 TRACTOR (A62130)
JOHN DEERE 4440...
2016 FREIGHTLINER CASCADIA 125  T/A DAY CAB TRUCK TRACTOR (A59909)
2016 FREIGHTLINER...
2018 Ford F-150 4x4 Pickup Truck (A61568)
2018 Ford F-150...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
