grading a long lane
   / grading a long lane #1
yanmars
I have a 10 foot wide lane over 1700 feet long that will eventually be over 2000 feet. I have a 33 and 45 horsepower Cat 1 tractor. Would a box blade or angle blade or whatever be the best for light grading and maintaining the lane etc.
Any comments, suggestions, reasons would be appreciated. Thanks
   / grading a long lane #2
[just a comment]
remember, it is best (whatever you grade with) to make the (storm water) run-off cross the road (into a ditch etc.) rather than "down the road"
   / grading a long lane #3
I would use a 6' landplane grader for this type of work, these work great for smoothing the surface, and bringing the gravel to the top. This has been discussed at great length on the TBN attachment forum. Anyone who builds roads frequently needs to have several implements including rearblade, boxblade and landplane.
I use a rearblade for ditching, crowning and shaping, a boxblade for ripping potholes amd moving large amounts of dirt a short distance, the landplane for smoothing and maintaining.
   / grading a long lane #4
I have a 6' Landpride 3672 rear blade and a 7' boxblade. The box blade does have its place and when I built the driveway I used it alot. In 3 years I have used it once on the driveway to maintain it.
My rear blade however I have used quite a bit. As previously said keep a crown on the driveway and keep water to the sides and not running down the driveway. The rear blade I can offset to the side and roll any rock that gets pushed to the sides back into the center. I will drive the distance doing this on one side then the other. Once the rock is back into the center I set the blade back straight behind the tractor, reverse it (so as I am driving forward it is back dragging)... drive the distance of the driveway spreading the rock back into the wheel tracks then on the return trip I may polish up any places. Usually less than a 30 minute job for 2000' of driveway. Been here three years now and the first year i had to do more to it than the last year. This year I think I touched it up this spring to get any gravel that may have been pushed to the edges while removing snow back into the driveway.
The box blade is somewhere on the farm with weeds growing around it, haven't used it in a while, might actually be at my uncles place. For reference my tractor is a 45-50 hp utility 2wd tractor with a loader.
   / grading a long lane #5
Plus a landscape rake is also useful for maintaining.
Do you need to move snow off this road? If not I would get a box blade first.
   / grading a long lane #6
Agree and the rake would be my second or third choice after the rear blade...unless you are making a new road a plane is not really needed in most cases IMO...
   / grading a long lane #7
In the end I would want to own a grading scraper (land plane) for a road that long. But for building a road it wouldn't be the best choice. Ever since finishing building my driveway I haven't touched a boxblade. I was lucky and had a couple of friends who had them so finding one to borrow was easy. Both thought the BB was the greatest tool for driveway work until they actually used my GS and now they both are planning on buying or building one. Have you looked around to see what you can rent or borrow?
   / grading a long lane #8
   / grading a long lane #9
My driveway is exactly one mile (a full section) long. It was built for me to access my property. I only use a back blade (Land Pride RB3596) to maintain it both summer and winter. Never used a box blade because I've not needed to move that much dirt, gravel etc. I reverse the blade and drag it forward to smooth in the spring while things are still damp. Later when it dries the backblade in its normal position & going forward causes "cupping" so the majority of maintenance is a spring time affair. We can get a lot of snow in the winter so the backblade removes the snow. I guess if I ever needed summer maintenance I would get some type of land plane. So far this procedure has worked fine for the 31 years I've lived here.
   / grading a long lane #10
All good advise. A lot depends on the make up of your lane, it's steepness, and your local weather. A guy in Florida with a level pea stone drive who never plows snow would probably be satisfied with a rake while a guy up north with deep winter frost, which makes for muddy springs, and a hard packed gravel hilly drive needs more than a rake because he has to cut and move hard packed gravel to grade his road which a rake won't do by itself. I have such a road about a mile long, The lower half is a good road with a proper base and good gravel the upper half was a dirt logging road that I upgraded over time little by little by mixing in stone with the dirt. I used a rear blade for 10 years to maintain it. Then I got a land plane. Now I use both but mostly the land plane. It is a great maintenance tool.
There are lots of considerations. Check out what people around you with similar drives use and compare it to what has been said here, there is a lot of experience to read about here.
If you do much tractor work you will probably end up with several dirt tools. They all have there place and main specialty or purpose but they also can be used effecively in a wide range of work outside of there specialty. I would say the rear blade is the most general purpose and universal road tool. Buit it takes a lot of time and practice to develope the skill to use it at it's maximim potentential. The box blade is less universal but easier to master and better for moveing dirt than the blade. The land plane is surface maintenance only, leveling pot holes and wash board, rejuvinating and mixing gravel, and maitaining crowns. It is easiest and fastest to use by far so you can keep your road in better shape. By keeping the road in better shape you get less damage from storms or traffic.
This is just my opinion of course. Many have different ideas.
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2015 FREIGHTLINER M2 DAY CAB (A51222)
2015 FREIGHTLINER...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
