Tram pump issues?
/ Tram pump issues? #1
frischtr
Harford County, MD
PT-425
Hopefully it's something else, but I believe my 425 tram pump is on the fritz.
Nearing the end of my mowing chores for the day I lost about 50% or so of my forward and reverse speed. Flipped off the PTO circuit right away to take load off of the engine. The treadle seems to work properly, but the PT is sluggish to move forward or backward, and with greatly reduced torque and speed. The pump whines even when not moving, never did that before. No creep when off the treadle. No broken hoses or seals that I can see. PTO and steering/aux circuits still work fine.
BTW this is the new style 425 tram circuit, not the hydroback style. 2010 PT-425, 180 hours.
Could it be a wheel motor instead of the pump? Or the treadle valve? The whine from the pump is what has me concerned. I'll be calling Terry tomorrow, but any ideas on what to try in the meantime?
~Tim~
/ Tram pump issues? #2
What you describe is what happened to me. My tram pump went out at 50 hours. Glad it was under warranty, it is very expensive to replace. Power Trac said my swash plate just fell apart. I could eventially push or pull my 425 like a wagon. Absolutely no resistance on the wheels at all. Terry said he never seen one go that early and that bad. Mine was still under warranty thank goodness.
/ Tram pump issues?
Yep, I have an idea of how much they are. As you can imagine, I'll be pretty pissed if that is, in fact, the problem at 3 years and 180 hours old.
/ Tram pump issues? #5
Did you perhaps do an air bleed on your pump recently?
If so, did you turn the bleed screw fully closed.
/ Tram pump issues?
Could there be something obstructing the intake like maybe a bad/plugged hydro filter? Good luck.
I doubt it, PTO circuit and steering/aux circuit work great.
None in the last 30 hours.
Terry said with the whining sound, its definitely the pump. Off to PT for a look-see...
/ Tram pump issues? #7
Do you not have a separate pump for the PTO and steering.
I have three hyd pumps and all the tram pump does is to power the wheels.
/ Tram pump issues?
I believe the filter is only used in the tram circuit.
Yes, after looking more closely at the drawing you are correct. Worth a look tomorrow before I unhook the pump. I just took the fuel tank, battery, and tray out this evening and vacuumed the tub out.
/ Tram pump issues? #11
I've mentioned this before, but it is worth mentioning every time....
If you disconnect any hydraulic hoses or open any ports, be prepared to plug them. You can lose a tremendous amount of fliud to your garage floor overnight if a hose is left dangling or a port is left open. There's 10 gallons in there. ;)
/ Tram pump issues? #12
The full 10 gallons wont end up on the floor, just most of it.:eek:
/ Tram pump issues?
Indeed. Just got home from work and I stopped on the way to get some plugs.
/ Tram pump issues?
Terry says cracked cam plate. Pump repaired and on its way back... At least it was a quick turn-around.
/ Tram pump issues? #16
Yes that was fast. Good for you. Let us know how the re-install goes. :thumbsup:
/ Tram pump issues?
Back up and running great:thumbsup:, though my wallet is $500 lighter:(...
/ Tram pump issues?
Well, well.... Unfortunately I have to bump this thread to the top.
I was turning over the compost pile with the bucket and heard a snap from the back. No drive, but the aux circuit works, so I figured it wasn't the input shaft to the pumps. Pulled the tram pump out and hear all kinds of rattling inside.:thumbdown:...
450 hours on the machine, 270 hours since the pump was rebuilt by PT. Off to Tazwell again :mad:
This is what I was able to work out of the pump:
/ Tram pump issues? #20
Oh boy, ya that doesn't look good for the pump. I think those parts should be inside, and probably not so many of them.
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
2011 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2011 DRAGON 150...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
2009 Kubota ZG222 (A60463)
2009 Kubota ZG222...
