pouring concrete dry
/ pouring concrete dry #21
If you compare prices you may find that having a truck come is less expensive than buying pre-mixed bags.
I mixed approximately 133 80# bags of concrete for my pole barn thinking that mixing it myself would be cheaper then having a concrete truck deliver.
Six months later, while building a new home I needed about the same amount of concrete to support a 16x24 ft. deck. Because of the size of the concrete pillers I was afraid I wouldn't be able to mix the concrete fast enough to keep part of it from drying before I was finished so I hired a truck to deliver the concrete.
Even with the extra charge for ordering under a certain amount of concrete I still came out cheaper then if I'd mixed it myself. Oh well, you know what they say about assume.
You'll never beat truck prices with pre-mixed bags. about the best you can do is break even. unless you get the really cheap stuff which isnt nearly as strong.
But you can beat the price if you buy bags of portland, sand, and gravel and mix your own. Last time I bought, a bag of portland was ~$10 a bag. For a 6-bag mix, (6 bags to a yard), thats $60. And a yard has about a ton of sand and about a ton of gravel. Sand is about $10 a ton and gravel is about $16 a ton. So for $86, you can make your own. BUT....for only about $20 a yard more, you can get a truck to deliver it already mixed:thumbsup:
Another thing I dont like about the bagged premix for larger jobs is IMO the stone is just too small.
/ pouring concrete dry #22
Don't know if cheaper , but once done , the wall looks a heck of a lot better than cinder block or plain concrete wall .
8 in. x 12 in. Red Charcoal Concrete Garden Wall Block-M0404COTA181 at The Home Depot
I currently have 3 walls with the highest being 3+ feet tall and have drove my TC 30 New Holland along the edge without any movement of wall . I purchased mine at a local Masonry / brick / rock supplier . They actually make them on site so they are a little cheaper than big box stores . The link I posted is similar to what I used , but mine weigh in at 67 lbs. a piece . First layer Sucks . Pick up and lay down each block several times till it is level and pitched , but after that it goes pretty quickly , at least as long as your body holds up .:thumbsup:
Fred H.
I purchased blocks like that from Lowes. They totally disintegrated in 2 years. I personally like the ones from Pavestone, That's what I used for the retaining wall around my 11,000 gallon Koi pond.
Retaining Wall Blocks |
/ pouring concrete dry #23
I personally never used Lowes or Home Depot's blocks . That is just similar to what I used . Mine are made Locally by a Company that if I not mistaken supply those same blocks to just about everybody here locally . Mine have been in place for better than 6 years and other than some discoloration from minerals in water when lawn sprinklers do their thing , they are still solid . As I stated , if you look at the one's in the Lowes link , their weight is maybe half the weight of the blocks I have . Think mine are 6" x 16" . Have made both outside and inside corners , but once completed , The look is far better than anything else .
Fred H.
/ pouring concrete dry #24
For a retaining wall, I agree that stacking blocks is the best way to go if it's not too high. This is what my 77 year old dad is doing by himself. He does a little bit at a time, and when he feels like it, he goes back and does a little bit more.
These are from Lowes.
Eddie
/ pouring concrete dry #25
FWIW...
General rule of thumb for mixing concrete by hand is "1-2-3"...meaning one part portland, two parts fine aggregate (sand) and three parts course aggregate...this will give you roughly a 2000# compression PSI with enough water to test with a 4" slump...adjust the portland/water ratio to increase the compressive strength...
in cold weather climates is is recommended to add an air entraining agent
When mixing by hand the "1-2-3" rule make it easy to remember and using a pail or bucket to measure helps
/ pouring concrete dry #26
I know there are going too be some comments because i always here you can't pour dry concrete for fence poles but my 2.5 acres has a 6 ft fence around it coming on 15 years know & is solid as a rock, anyway what i'am getting @ is, i want to pour a retaing wall 4 inch thick with rebar & about 25 ft long & probally 3 ft tall & was considering pouring it dry & was wondering if anyone has any experience with this i want to put a car port next to my shop with gravel base to park a boat but it slopes away & will need to raise the outer side up 3 ft to make a leval pad, will frame up & pour H20 as i fill & probally keep a sprinkler on the forms to keep wet for a couple of days any exp. doing this???
I seriously doubt that a 4" thick by 3' high retaining wall is strong enough to work, no matter how much rebar you put in it.
Most retaining walls have a base or foundation which is much wider than the wall. Even the stack block walls usually require a base of 3/4"- gravel, well compacted.
In most places, walls under 4' do not require engineering, so you can build whatever you want. But, when I built a 5' retaining wall to hold the earth for driveway, I used stack block, but both read the brochures on how to do it with that brand of block, and had an engineer design it. Select a brand of stack block and look them up on the internet. Most have a wealth of information on how to do it right.
Another thing to consider is that randomly mixing blocks of various colors produces a very pleasing look.
Higher quality block than Lowes or Home Depot carries will cost a few $ more, but will give a much better end result.
Any way you look at it, a well made retaining wall is going to be hours of backbreaking work. Spend a little more and get a lot more.
/ pouring concrete dry #27
Expensive truck prices.. last yard I bought was only $80, and the driver helped me spread it.. The place here has 'specials' on Saturdays for residential low quantity pours. Ask them..
/ pouring concrete dry #28
I had a few bags of quickcrete left outside but never got wet. They sat for years. They set up hard but they didn't have the same strength.
/ pouring concrete dry #29
What's wrong with concrete "H" blocks set on a solid reinforced foundation? I did mine that way. It has the 8" wide blocks, with mortared joints and rebar set in the concrete foundation that the blocks slipped over. All openings were back filled with concrete (wet), and it was capped with used bricks, perpendicular to the blocks.
Oh, I must mention i did not mortar between the ends of the blocks, they were butt joined, but each row was mortared. This allows the excess water to dran through to the planters in front of the walls. It works very well too.
/ pouring concrete dry #30
Nothing wrong with what you describe just a finished appearance that won't please most head landscapers AKA "She who must be obeyed".:)
/ pouring concrete dry #31
Finally!.......CurlyDave hit it.....you can't expect much strength from a 4"thick retaining wall. Do at least a 6"thick wall for even a 3' high wall. Notice I said pour it......if you hand mix it,add extra cement to each bag,unless you buy the hi-strength type. Just one bag of 94 lbs. cement(one cubic foot)will add a lot of strength to one cubic yard of crete. don-ohio Concrete contractor for many years. :)^)
/ pouring concrete dry #32
I built a house using tip up concrete walls 8' high by 4" thick. One wall was 9' high. None of them cracked when I tipped them up with my loader. I had to use 6000# concrete and rebar on 1' centers both directions if I remember correctly. A thin wall can be quite strong, but of course will tip over easily if not held up somehow.
/ pouring concrete dry #33
Actually momma preferred the look of the blocks over poured concrete. :thumbsup: I do agree that some do not like the looks of blocks. It was a simpler way for me to build a wall. The only forms needed were for the footer.
/ pouring concrete dry #34
1. The OP did not mention any plans at all for a footer.
2. The forces on a tilt-up wall are much different that those on a retaining wall. A relatively thin wall is fine for the tilt-up design, but a retaining wall must resist much higher lateral forces.
/ pouring concrete dry #35
You really should look into calling an onsite dry mix truck. They can mix any slump you want, can carry roughly 8 CY (although if making 4000+ psi they probably don't carry the Portland for 8 CY). You pay about $150 per CY (compared to $110 for ready mix truck) but you only pay for what you need, and they can change the slump as you go. Works great, but may or may not be available in your area. My old project manager told me anything less than a yard quikcrete is cheapest, more then 1 but less than 6 dry mix truck, anything 6 or more ready mix.
As to strength, we regularly pour 18" trench curb (12" above ground, 6" in ground, 6" thick) as a micro retaining wall, but 3 ft tall screams for at least an 8" x 8" footer and 6" wall at a mininium. Personally I would probably do 12" wide at base, formed face with plywood and strongbacks, and taper from 12" at bottom to 4" at the very top, vertical face, and use earth formed back, pulling dirt down as you pour to create the taper. Tap the face board as you pour to minimize honey comb. Don't strip form for 8 hours.
/ pouring concrete dry #36
Yes,the footer is important,as Dave says,and you can just widen the bottom as paul suggests.I've done it both ways and other ways,and the strength gained is enormous over just pouring a 4" wall. Sure ,a 4"wall at SIX THOUSAND PSI test full of rebar perfectly placed with vibration is as strong as a 4000 psi, 5" thickness, but who wants to try that(with home-made forms) on a retaining wall 3' high? Just pour it 6-8" thick,with some rebar and specify mix without a lot of entrained air(total 5% is way plenty) and NO flyash,just 6 bags of cement per yd. and you'll be fine. Take a coupla test cyls. if you doubt the veracity/integrity of the batch man or concrete company you're dealing with. don-ohio :)^)
/ pouring concrete dry #37
A retaining wall is a dam that is holding back the weight of the dirt piled behind it and is trying to flow down hill when it is saturated with water in the spring. Ret walls don’t break they tip over.
I worked on one that was up to twenty feet high. The footers were a minimum of two feet thick and ten feet wide poured on solid ledge blasted and hand cleaned to a pay line. Then rock bolts one and a half inches thick were drilled through the footers and ten feet into the bottom ledge and epoxied into place. They were all jack tested to 100,000 lbs tension and passed. Then the mass concrete was poured above in thirty foot wide sections with a vertical front face and the back battered three on twelve. The wall was a foot thick at the top and up to six feet wide at the bottom. The whole wall was over 1000 cubic yards of 3000 psi min. concrete. It only takes the flow of the Connecticut River when it is in flood and holds up forty feet of fill with a highway on it so I expect it will serve for five hundred years or so.
Build it right the first time and be done with it.
/ pouring concrete dry #38
Hey,PaulHarvey!We used to have the dry mix trucks(they would carry 12 cu.yds.!) here in Jackson and Wellston,Ohio in the mid-seventies to maybe 1983 or so. I poured thousands of yards with them,but a problem developed which made me quit using them. The cement bin apparently was getting wet and clumping causing a shortage of cement richness per cubic yard.I poured one driveway which came out spotted with the richer gray color and weaker whitish color every few square feet.
Have you ever had this problem? don-ohio :)^)
/ pouring concrete dry #39
I have not, but I haven't used onr in 4 years, dry mix isn't FDOT approved because they can't give a true "mix design". We used to use it pouring curb, were you need about a 1.5" slump, and if the ready mix driver brings a 3" you either have to send it back, add Portland into the drum, or make him sit till the mud first starts to get hot and then pour like heck. Another thing is I guess a lot depends on the quality of the dry mix driver, in Gainesville FL, they made good mud, but everyone in Ocala FL, says there locals make crap mud and don't seem to know how to fine tune slump and water-cement ratio.
/ pouring concrete dry #40
To bring back a 5 year old thread..I recently poured about a yard of concrete. Sprinkled might be a better word, since my concrete mixer broke right as I started the job,
and doing it wheelbarrow at a time not appealing. So what I did was a) wet up the dirt good. b) pour/spinkle/spread out the dry concrete in the form, sprinkled water on it until all wet. Repeat again. One thing this does is keep the rebar/mesh from just pushing to the bottom which happens when you dump a big load in. Since I had no real support for the mesh, the concrete goes under it and lifts it. Once I got 3/4 of it filled this way, the mesh is then sitting on top of the concrete. Now I mixed the rest in the wheelbarrow and poured it on top, and fininshed it as usual. Came out great. This was a **** of lot faster than mixing it all in a mixer even, let alone a wheelbarrow.
I am thinking of doing this on a bigger scale for my barn floor, so went searching if others did it. Of course most say 'no way, won't work', but then other examples are given showing it works. HA. And it worked for me. And btw, at 1 yard size, homedepot discounts a pallet so it is say $120/yard. The onsite-mix people wanted $200 for a yard. The uhaul-it-mixed guys wanted $160, and you need 3/4 ton truck I don't have.
I usually make my own with cement/sand/gravel, but not at just 1 yard. If you make your own you have to mix it anyway, so this approach only works with premixed bags,
but at 5 yards the cost figures don't change too much. And let me also add I work alone, no way I can deal with 5 yards dumped at once, and the onsite guys start charging big money after 20 minutes of being there.
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2017 Ford F-250 Ext Cab Pickup Truck (A61573)
2017 Ford F-250...
2021 John Deere 835M XUV Gator (A63111)
2021 John Deere...
2014 Wanco FD-304 Folding Solar Towable Arrow Board (A61572)
2014 Wanco FD-304...
Caterpillar Service Manual Reference Kit for Motor Graders, Wheel Type Tractors, and Equipment (A63117)
Caterpillar...
