Backhoe BH77 owners
/ BH77 owners #11
Hi Ronster,
No problem on the pictures. Glad I could help. I am not sure if this is what you were asking for. If not, let me know.
/ BH77 owners #12
Well I have the bh77 backhoe on my L3800. Now I want the OEM thumb. So I go to my dealer and get a price last year $465. Then He says $200 to install it and tax. Thought I was capable of installing my own thumb or is it a warranty issue?? The reason I am a bit paranoid is that after buying the L3800 I noticed that the right side hand grip is missing and was told you have to buy the grand series to get that or pay extra for one. So I built my own out of a 2x4 and bolts. I use it a lot too. When I had the rim guard ballast put in, the home built hand grip was noticed. When I bought the tractor in Feb. 2011 I asked for prices and was told $950 for a thumb. I think the correct thumb is BH1976 but nowhere can I find that in any Kubota literature.
Anybody else have these experiences or do I have to find a new dealer.
/ BH77 owners
Thanks Russ. That's the measurement I was looking for. I believe this thumb will fit my kx008. Just need to fabricate the bracket for the pin on the stick. Got one price of $475 plus a little shipping. I'll shop around a little more.
Ronster
/ BH77 owners #14
DB Pilot,
You are correct, the thumb appears to be listed as the BH1976. If you do a build quote on Kubota.com and when finished print the quote it will pull up an Adobe file showing the BH1976 number. I did not know a good way to put the link in the post, so I copied and pasted. Scroll to the bottom and you will see the price when building the tractor of $475.00. If your dealer quoted you $950, then yes you need a different dealer. You should be able to buy the thumb now as whole goods for around the $475.00 price. I have links above to Keller Kubota and Messick's. I would call both of them and Lashley Tractors and get prices. I think Artisan had said in the past that Lashley had good shipping prices. Lashley Tractor Sales -*Home I just can never seem to look up my parts on their site. They have listings for some parts. Maybe I need to register with them. Good luck and happy shopping.
Russ
-- Standard Features -- -- Custom Options --
L Series L3800HST
* * * EQUIPMENT IN STANDARD MACHINE * * *
DIESEL ENGINE
Model #D1503
3 Cyl. 111.4 cu. In.
^ 35.9 Net Eng. HP
^ 30.0 PTO HP
@ 2700 Eng. rpm
Interim Tier IV Engine
Indirect Injection (E-TVCS)
12V – 490 CCA Battery
Charging Output 40 Amps
Electric Key Shut-off
HYDRAULICS
Open Center - Gear Pump
6.3 gpm Remote/3 Pt. Hitch
3.8 gpm for Power Steering
10.1 Total gpm
Cat I 3-point Hitch
At lift Point 1998 lbs.
24” Behind 1435 lbs.
FRONT AXLE
Integral Power Steering
Bevel Gear, 4WD
Cast Iron
Tread Spacing, Nonadjustable
^ Manufacturer Estimate
DRIVE TRAIN
Hydrostatic Drive
3 Speeds L-M-H
Multiple Wet Disc Brakes
Clutch – Dry Type / Single
Stage
Differential Lock
DASH INSTRUMENTS
Tachometer w/Hour Meter
Fuel Gauge
Temperature Gauge
FLUID CAPACITY
Fuel Tank 10.0 gal
Cooling System 6.3 qts
Crankcase 7.5 qts
Transmission and
Hydraulics 6.2 gal
POWER TAKE OFF
Live-Continuous Running
Speed - 540 @ 2425 Eng. rpm
540 rpm Rear PTO – 1 Speed
SAE Std 1 3/8” Six Spline
SAFETY EQUIPMENT
ROPS w / Retractable Seat Belt
PTO Shield
Safety Start Switches
Mechanical Wet Disc Brakes
Parking Brakes
SMV Sign
Turn Signals / Hazard Lights
OPERATOR STATION
Color coded controls
Wide platform steps
High Back Seat with Adjustable
Suspension
Operator Presence Control System
Optional Cruise Control
Cup Holder
SELECTED TIRES
AMR8977A & ALR8809 INDUSTRIAL TIRES
FRONT - 27x8.50-15 R4 Titan Trac Loader TL
REAR - 15-19.5 R4 Titan Trac Loader 3.6"offset
L3800HST Base Price: $19,134.00
(1) FRONT LOADER PACKAGE (855 LBS LIFT
CAPACITY)
LA524-FRONT LOADER PACKAGE (855 LBS LIFT CAPACITY)
$4,182.00
(1) 66" QUICK ATTACH SQUARE BACK BUCKET
(HEAVY DUTY LOADER PACKAGE)
L2256-66" QUICK ATTACH SQUARE BACK BUCKET (HEAVY
$623.00
(1) SUBFRAME KIT FOR BACKHOE
BH4988-SUBFRAME KIT FOR BACKHOE
$754.00
(1) 7.7 FT BACKHOE
BH77-7.7 FT BACKHOE
$6,844.00
(1) 12" PIN ON BUCKET FOR 7 FT BACKHOES
BT1951A-12" PIN ON BUCKET FOR 7 FT BACKHOES
$491.00
(1) 6 POSITION MECHANICAL THUMB KIT FOR 7
FT BACKHOE
BH1976-6 POSITION MECHANICAL THUMB KIT FOR 7 FT
BACKHOE
$475.00
Suggested List Price w/ Options: $32,503.00
*Taxes, shipping & handling, surcharges, assembly charges, destination, freight and/or delivery charges are not included.
This MSRP configuration program is for informational purposes only. In all instances, the user of this program must consult with an authorized Kubota Dealer for
complete purchase, warranty and safety information. Special pricing and promotions may be available on certain models. See your Kubota Dealer for details and
individuals Dealer product pricing. All prices are shown in U.S. Dollars. Quotes are for products sold in the United States only.
© 2013 Kubota Tractor Corporation. All rights reserved.
/ BH77 owners #15
Ronster
Hi Ronster,
Was $475.00 the price for the whole kit? Whole goods? It might be what you have to pay from Kubota. Possibly shopping around or if your dealer wanted to take good care of you, they could knock something off that. I know for all my John Deere stuff in the past, my local dealer would knock, if I remember correctly, 15% off list.
Russ
/ BH77 owners #16
Thanks 1savoy, I have been thinking of Messicks and now Ashley's but may try another dealer nearby.
/ BH77 owners
Russ,the $475 was the price a dealer gave me and add some shipping to that. I'll call Messicks this week for their price this week. Also need to get a little steel to make the brackets to mount the thumb on the stick. Dose the BH77 use 1/4" or 3/16" steel for the factory brackets? Thanks.
Ronster
/ BH77 owners
Ps...... That was the price for the whole kit. Parts prices for the thumb piece and pin were about $454, might as well the entire kit. I can always add the hydraulics later if I want to.
/ BH77 owners #19
Ronster
The brackets appear to be 1/4" exactly. I am not sure the powder coating thickness, but it is hard to imagine it being 1/16" ????? If it was me, I would use 1/4". Hope you find someone willing to knock a little off on price, even though the $475.00 is not bad I guess.
/ BH77 owners
It's the high cost of our addiction to tractors and expensive pieces of welded metal. I can find some 1/4" stock somewhere and bushings at TSC. Thanks.
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
DEUTZ MARATHON...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
2017 ATLAS COPCO CPS110 PORTABLE AIR COMPRESSOR (A59823)
2017 ATLAS COPCO...
1990 TRAILMASTER CRUDE TRAILER (A60736)
1990 TRAILMASTER...
