thinking about trying this
/ thinking about trying this #1
allen6634
hawesville
600 ford
i just bought a fel and i have been thinking about attaching a bush hogg to the front of the loader, i think that will give me the ability to keep my ditch banks down,(and hopfully the string trimmer lol) i am thinking of building a 3 point set up but im going to have my top link hydraulic so i can adjust the angle. im also thinking that might allow me to use other implements with ease.
/ thinking about trying this #2
Do a search here on TBN ...another poster is doing the same thing and others have posted about it..you could share Ideas...post back..
/ thinking about trying this #3
Just be careful, a FEL isn't meant to sustain side-side forces that a (skidded implement)bush hogg could inflict. I'd hate to see the damage that could occur.
/ thinking about trying this #4
If you wanted your implement in front, you should have bought a skid steer to begin with. They're designed that way. I think you're in for some serious repair bills and/or a whole lot of headaches.
/ thinking about trying this #5
Has been done by Farmerford. I have thought about doing this myself. Look at this thread. Mowing Mower on FEL It's been six years since he did this. He could probably give some good advice on what to do and not do.
/ thinking about trying this #6
Would you use a hydraulically driven cutter?
Check pump capacity.
Do you have a way to run a PTO shaft from the back to the front, if not hydraulic?
the cutter will run off hydraulics
i understand that a tractor fel arn't designed to be side loaded, i am mainly just wanting to dip the cutter in my ditch , i have no plans to put any side loades on my fel
/ thinking about trying this #9
I'll be surprised if the tractor hydraulics are strong enough to run a hydraulic rotary mower. By the time you add a pto driven hydraulic pump and fluid storage container it is going to make for a pretty expensive mower. I do believe it is doable though.
MarkV
i have a seperate hydraulic pump that runs the fel im thinking of using this .
/ thinking about trying this #11
I don't think it would have enough GPM flow to run it.
/ thinking about trying this #12
You guys sure know how to crush a mans dreams.
/ thinking about trying this #13
I say try it, part of owning a tractor is doing stuff with it that other people only dream of.. I've got a brand new bx23 and trying all kinds of stuff this idea is just way to cool
/ thinking about trying this #14
No, just trying to help him do it in a way that works. It can be done, it has been done.
I use a 7' brush hog that was designed for the front. It has a front wheel and a hinge built into the attachment plate, so it can follow the ground contours.
Right click on each picture to open in a new tab.
/ thinking about trying this #15
We're not trying to discourage anything.
Just trying to weed the "stupid" out of a "neat" idea.
Not all neat ideas are stupid, but many have a stupid component within them.
For instance:
Not having the hog's curl angle adequately limited during use and eating a thrown blade would be stupid.
And tragic.
i'm hoping i can find a motor that will work with what i have if not i guess i'll have to do a up grade.
View attachment 318948 View attachment 318949 View attachment 318950 View attachment 318951 View attachment 318952
that is a great design i will use that with my mower
thanks i figured if this works or not i will gain two things (1 i will go through my junk box and 2 i will know that this was a bad idea lol)
/ thinking about trying this #19
Here are some pictures that show the front view with the safety chains and the cutting height adjustment.
Here is the same brush hog set to the highest cutting position, mounted on the V417
