canucklehead
Gold Member
- Joined
- Nov 29, 2006
- Messages
- 314
- Location
- frozen Canada
- Tractor
- 1979 Ford 1500, Toro 455D 10' mower w/ Renault diesel,
I took apart and cleaned carb on my '62 IH B414. I was able to clean the jets and got good carb cleaner spray and blew air through them. My problem is fuel flow. I can dump gas in through carb and tractor will run. The moment I stop feeding it fuel, it sputters and dies.
There is a large butterfly valve on top of carb controlled by a choke cable. no problem, that works.
There is a second, smaller butterly valve controlled by the throttle cable. This is where I think my issue is. This valve would not fully open. It has a rod/lever connected to something inside the float bowl. I'm guessing that lever is connected to the accelerator pump (but could be out to lunch on my guess). Whatever that rod connects to is seized. So I banged on what I'm calling the accelerator pump and got it down deeper inside float bowl. Now I can at least see the smaller butterfly valve open and close when I move the throttle cable. But the "accelerator pump" is still not moving and is now stuck in a down position. I suspect it is supposed to slide up and down freely with the rod connected to the valve.
So would this seized part cause me to have no fuel flow? Anywhere I can buy a new float bowl and "accelerator pump" ?
I loosened the fuel line fitting at the carb and cranked engine and fuel seemed to flow well from the fuel pump to the carb.
One other possibility (doubtful)...... when I pulled off the float "needle" flap (it's not a needle, it's a flap), I didn't pay close enough attention to which way it sat. The flap says "top" and I positioned it so "top" was facing up (as in I can read "up" when the flap sits on top of float bowl), so i think I got that part correct. I think when the float raises this flap pushes on the needle to stop gas from overflowing into float bowl (??). Anyways.... possibly i got this upside down or incorrectly installed and needle isn't opening to let fuel in (??).
