60" Finish Mower Problem
/ 60" Finish Mower Problem #1
kootch88
Gray, Me
2012 Mahindra Max 22, JD Stx38, JD Stx46
Fired up the mower this weekend only to find it smoking like a chimney. I greased the 3 spindles before starting only to find one bearing was ceased up in one spot. I got a wrench on it and was able to break it free and greased it again after turning it several times. Ran like a champ. Never saw a bearing cease like that on an item that has maybe 10 hours on it. I am guessing it wasn't greased properly from the factory and I created some wear running it dry. Hope I solved the problem.
/ 60" Finish Mower Problem #2
I would use a lithium high temperature grease ONLY on bearings. It may help but there is defiantly some damage. On linkage and ball joints your every day grease works just fine.:2cents:
/ 60" Finish Mower Problem #3
I was having some spindle problems on HOWSE finnish mowers this past summer. The spindle housings were so large that it took 150 grease gun pumps to fill it. If you only filled it part way, when it got warm all the grease would settle to the bottom and lubricate the bottom bearing only. I replaced about five of them before I figured out the cause.
/ 60" Finish Mower Problem #4
Holy cow Galen! My hand is tired just thinking about squeezing that many times to grease one spindle...
/ 60" Finish Mower Problem #5
Here's what I use. It's proven to be very handy. Lot's of folks complaining that the fitting adapter is too tight. After hammering it off of the first zerk I used it on, it loosened up.
/ 60" Finish Mower Problem #6
I was going to get one of the air grease guns, but am going to hold out and get one that uses batteries. I have both DeWalt (drill) and Ryobi (several) that use batteries so will eventually get one that uses batteries that I already have. I don't like having to drag an air hose out to grease... but then again, it would be better than doing it by hand on several of the implements..
/ 60" Finish Mower Problem #7
Makita makes one that will work for you. I use the Makita LXT Li-ion cordless tools, and want a grease gun that will take the battery directly, without mounting it on my drill. I'm still waiting for that one. :laughing:
PALLET OF TOOLBOXES (A68842)
PALLET OF...
2020 CATERPILLAR 316 FL EXCAVATOR (A65056)
2020 CATERPILLAR...
PORTA POTTY (A68842)
2000 FREIGHTLINER FLD120 (A67714)
2000 FREIGHTLINER...
2019 Toyota Camry Hybrid Sedan (A66738)
2019 Toyota Camry...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
