Any CPAP users?
/ Any CPAP users? #1
westbrooklawn
North Carolina
kubota L3400HST
I just completed a sleep study and CPAP titration study, and I expect my Dr. to be in touch with me in the next few days to recommend that I go on a CPAP machine. I really dread it, since I don't like the idea of being constricted, and the CPAP was not too comfortable during the test. Just wondering how many on this forum might already be on a CPAP, and looking for any recommendations. Thanks!
/ Any CPAP users? #2
You get used to it. You too can be a Borg.. resistance is futile.:)
/ Any CPAP users? #3
:D Yep, I have been using one every night for about 8 years myself. It wasn't easy at first. I hated it. In fact I wanted to bury it in the back yard (but it cost too much). The best advise that I can give you is to try to make friends with it. You and it can become one in time if you try. One of the main things with the CPAP if finding the right mask for you. For example, I started out with a large full face and wound up with a medium nasal mask. I would have thought the full face would have been the ticket. The CPAP has certainly helped me to rest at night and feel better during the day. I certainly wish you the best with it.
/ Any CPAP users? #4
All CPAP users have a love-hate relationship with their equipment. Been using it for 10 years now. Had lots of trouble finding the right mask. Went through the nasal plug types, the old inflexible kind, the full-face, etc. Settled on the Res-Med one that kinda inflates against your face. Much better for me. No leaks and it sits lightly on your skin. It is important to find the mask that works best for you, and to learn to adjust it properly. It's also important to replace at least the soft part of the mask when the manufacturer says, usually every three to four months. It gets warped in its shape, even if you don't notice any visible change, and it will not fit as well.
But if your CPAP works, you'll begin to sleep a lot better, and wake up a lot more refreshed. If you have sleep apnea and do nothing about it, it will not only keep you tired all the time, it will literally knock years off your life. Good luck.
/ Any CPAP users? #5
I just went through my second sleep study Sunday night which is for the mask fit. My next visit I will be getting the machine I think. The one I chose was the medium nasal mask so hopefully I can get used to it. Dont have any recomendations yet as I am a newby myself.
/ Any CPAP users? #6
Once you acclimate to using one, you don't want to be without it. It makes a major difference in quality of sleep.
A nasal mask is what I prefer, but if you tend to let your mouth open during sleep you may need to go with the full face (unless you are OK with a chin strap).
See if any of the available models offered to you can run from a 12 volt source without an inverter. If so, a fully charged deep cycle/trolling motor battery can make for a good backup (i.e. multiple nights worth) if you get an extended power outage or are away from 120v.
Nick
/ Any CPAP users? #8
Hi Folks
I have been using a CPAP for 13 years, on my 3rd machine, at beginning my experience was as described in earlier threads, very difficult to get used to. However as an equipment operator I had to persevere after 1 year things were much better. Now I cannot do without it, if I must sleep one night without it I am very tired next day, more than one night and I cannot stay awake.
The mask is the most important variable, I have tried many, now I use a full face which covers my nose and mouth, it is the inflatible seal type, Resmed Quattro is the name of it.
The CPAP is now an important part of my life, I use it faithfully every night for 7-8 hours, I am very used to it and cannot sleep comfortably without it. My wife who works in respiratory therapy is of course very supportive of me using it and has not abandoned me once in bed because of it, this I count as a real blessing.
I hope to add a few years to my life because of this machine and strongly recommend if one is prescribed to work with it until a comfort zone is found for you. Mine operates with a humidifer and the pressure settings start at 13 cm/h2o and ramp to 17 cm/h2o.
Troy
/ Any CPAP users? #9
Resmed Mirage Quattro for me.. I tried the nasal ones years ago, did not work for me. Besides they seemed to hurt. I called them "nose knives". The point is find what works for you, and is effective and comfortable so that you use it every nite. Here is another little goody, apparently if you have untreated sleep apnea you are liable to have heart problems also..To tell you that joining the "Borg Collective" is fun would be a lie. BUT the benefits of being a "hose head" outweigh the alternative of untreated sleep apnea. Besides it is just for 8 hours while you are sleeping, the rest of the time, you are a "normal" person.:) Good luck with it.
James K0UA
/ Any CPAP users? #10
Been on one for almost 3 years now. The nose mask works well for me and wasn't too hard to adjust to.
I want to check out the dental device they claim works. It would be good for camping when power isn't available IF it works. Otherwise, the great outdoors isn't too peaceful with this bear growling...
/ Any CPAP users? #11
I used to use one and could not adjust. I now have a mouth piece made by my dentist that pulls my jaw slightly forward while I sleep. It helps. No noisy machine and no hose. Please consider this.
/ Any CPAP users? #12
I've had CPAP for about 15 yrs, on third machine and use my former machine if we travel. I've been through several masks, trying to find one that works for me and finally settled on the ResMed Comfort Gel. As mentioned in a previous post, it is a good idea to change the mask at recommended intervals, they're sorta like shocks on a car, don't notice them deteriorating till you get a new one. Stick with it till it works, no harder for me than getting used to glasses. Good luck and I think you will definitely notice a difference in how you feel through the day.
/ Any CPAP users? #13
One of my best friends needs one and has tried the nasal type. It didn't work for him and you can tell he is tired most of the time after stopping. I feel sorry for those of you that need the treatment, it seems to be a hard thing to deal with or without.
MarkV
/ Any CPAP users? #14
Besides marrying my wife (42 years ago), one of the best things I ever did was to get the CPAP:thumbsup:
/ Any CPAP users? #15
That's why I bring a marine battery with inverter along with an air mattress when camping :)
Dave
/ Any CPAP users? #16
I had a sleep study done using the dental device and it works. This was made by a dentist and not one I bought as seen on TV.
/ Any CPAP users? #18
I am one of the few people who actually felt worse after using the machine. I tried several different masks with no luck. The pressure blew my mouth open using the nose piece. The full face fixed that problem but I felt more tired when using it than not.
I have an appointment with a Dentist that is going to fit me with a mouth piece next week. I really hope that works. I am currently kicked out of the bedroom until I can quite down my snoring.
/ Any CPAP users? #19
I haven't tried one of those devices, but was wondering what happens if your mouth comes open when you're asleep, do you have to wear a chinstrap with those?
/ Any CPAP users? #20
I hate mine but won't sleep without it. Much better all around health , fewer colds, more alert, cheery disposition and fewer gasping snores to annoy Mrs B&D.
I'm fortunate that the nose piece is enough instead of the full face mask.
2001 Chevrolet Silverado Pickup Truck, VIN # 1GBJC34131F135556 (A61165)
2001 Chevrolet...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
(APPROX.18) (48) 2"X6"X12" TUBING (A62130)
(APPROX.18) (48)...
Cast Iron Anvil (A61569)
Cast Iron Anvil...
2 1/2 ft x 2 1/2 ft Metal Cage (A61166)
2 1/2 ft x 2 1/2...
2024 BOBCAT T66 R-SERIES SKID STEER (A62129)
2024 BOBCAT T66...
