part-time-Farmer-NC
Veteran Member
- Joined
- Oct 7, 2024
- Messages
- 1,069
- Tractor
- Kioti DK45Se
I'm on my third unit. Started with a phillips, that one started spraying black stuff in my full face mask. Replaced it with a resmed 10. I liked it so good I got a third resmed 10 as a standby. I have been using the bipap since 2003 right after my heart attack (I was 41). I rarely sleep without it. I say rarely because I don't seem to need it when i doze off on my recliner. Some nights I get so achy in my hips and knees I can't lay in the bed. I move to the recliner and can usually get a few hours of good sleep.
I switched to a nasal pillow type device about 2 years ago. Took a week or so to get used to. Up till then I hadn't ever used the humidifier with no issues. Now I use the lowest setting. I struggle with sinus drainage, have had that all my life. Allergies I'm sure. Takes me usually 30 mins to get to sleep after clearing my throat a hundred times it seems. THe full face mask really became uncomfortable to my forehead. In order to keep the mask from farting and waking me up I had to tighten it down pretty tightly.
On a separate note recently I have noticed that sometimes my machine smells like it has an electrical issue in the air discharge. I have put a air purifier beside the resmed but have since turned it off. Thinking it may be taking up too many amps for the circuit. I think I am going to try a ups next in case I am getting brownouts. I have tried it with or without the humidifier and do not seem to notice a difference. Doesn't happen every night, sometimes not even in the same week. First time I heard it I thought the house was on fire.
On a similar note I am planning a turkey hunt in late April. Was planning on taking a generator with me. When looking up UPS's I found a company that proved battery packs for the resmed. It also has a 60ah lithium battery that should last 10 ish days. I have a 100ah lithium trolling motor battery hmmm me thinks... I am reaching out to the company today and see if I can get their cable and use that. If so it oughta last me the 8 ish days for the trip. only takes 3-5 hours to charge so I may also use it permanently. Time will tell.
