How long can paint be stored?
/ How long can paint be stored? #1
Dan Hunter
Enid, OK
2012 John Deere 3720 eHydro
I bought a couple gallons of Parker Paint...the stuff people use to paint their aluminum boats and such. I intended to paint my truck with the stuff but never got around to it. They've been stored in my laundry room for seven years unopened in a cupboard between 68 and 78 degrees.
What's the chances they can be shaken and used? How would you check it to determine if it's still good?
/ How long can paint be stored? #2
Only one way to find out.
Chris
/ How long can paint be stored? #3
If its well sealed it should be fine, but will need lots of shaking. I've used 10 yr old house paint before.
/ How long can paint be stored? #4
forget trying to shake it and just get one of these
/ How long can paint be stored? #5
This will entrain some air. Settling in an unopened can is best addressed by a long shake ... but only if you know someplace with a machine that will do it for you. ;)
larry
/ How long can paint be stored? #6
If you have the time, would turning the can upside down for a few days help to incorporate the bottom sludge and make the mixing easier?
Good call on turning it upside down.
Shake with a machine? You're saying I can't toss it in the bed of the truck and let it bounce around for a month?
I'm taking it to Lowe's and asking if they'll rattle it for me. I'll try a bit under the hood and see if it holds well.
/ How long can paint be stored? #8
If it does mix well and look good. Test it before applying to your project.
I've seen old paint that did not cure properly. It remained soft. More so in the sun.
Edit: you beat me to it on the test patch thoughts. Good luck!
2021 Caterpillar 306 CR (A64126)
2021 Caterpillar...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
1996 Chevrolet 1500 Z71 (A64127)
1996 Chevrolet...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
John Deere 2 Row Planter (A65640)
John Deere 2 Row...
2008 Isuzu NPR Box Truck, VIN # 4KLB4B1U48J801742 (A65563)
2008 Isuzu NPR Box...
