My log skidding/ballast hitch project
/ My log skidding/ballast hitch project #1
PapaPerk
USA
Kubota L3830, Ford Golden Jubilee, 1939 Sears Economy, Polaris Ranger 400, Honda Foreman 450 ES, 2004 Dodge Diesel 3500
Thought I would share my latest attachment design.
I wanted a skidding hitch that also served as a trailer mover and ballast box. Nothing of this type was on the market so I developed one. My tractor, L3830 Kubota, does not have filled tires. So I determined how much ballast I needed by developing an axle loading equation in excel. :teacher: Here's a screen shot.
I determined wheel loading using a bathroom scale and long beam. :laughing: Worked great and is accurate enough for my purposes! :thumbsup:
To achieve 50/50 loading with loader empty, I need 550lbs of ballast at the 3 point.
I'll share pics of the hitch when time allows...
/ My log skidding/ballast hitch project #2
That's cool how you used excel to figure it out.
Yeah Excel makes the number crunching easy! Just gotta make sure I have my theory right. :reading:
Here's the pics.
Notice the use of choker chains and grab links. This is a great way to choke logs.
The hitch is ballast is visible in a couple pictures. Laser cut steel 1/2" plate. It looks small but this hitch weighs in at around 550 lbs. :blacksmith:
Also note is it compatible with my iMatch JD quick hitch.
/ My log skidding/ballast hitch project #8
Nice work!
/ My log skidding/ballast hitch project #9
Great idea, Superb craftsmanship. Many of us can't justify a $4k farmi for the amount of logging that we do.
/ My log skidding/ballast hitch project #10
It looks very nice. I like that it is qh compatible.
Thanks guys. It turned out pretty well. I notice a huge difference when using my loader. Much better weight distribution. Amazing what 500+ lbs of counterweight does!
It serves three purposes. Skidder hitch, ballast box, and trailer mover. The ball on the top is for goose neck trailers. Also it can serve as a winch anchor as the blade will dig into the ground when pulled in reverse.
/ My log skidding/ballast hitch project #15
that is some really great work, do you have any plans you could post.would really like
something like that
something like that
Thanks for the compliment! It has been working well!
/ My log skidding/ballast hitch project #17
Pretty slick. I've been contemplating building something like that when I get some spare time. What I'd really like to do is build one with a winch - but I'm having a hard time finding a candidate for a suitable PTO winch that doesn't cost a fortune.
With a skidder like the one you made - how do you get the logs to it - you must have either get the tractor right up on the log or drag it out a bit at a time before you can finally get the tractor right up on it.
Yeah if the logs are deep in the woods I pull them out with a long chain... Then reattach and hook up to skidder hitch.
Those skidder winches like Farmi makes would be great for logging. The pto winch is really slick. Not sure where you could get something like that for do it yourself.
/ My log skidding/ballast hitch project #20
Seems like there are often cheap PTO winches on Craigslist here, but they are from trucks. The problem would be making it reverse using a tractor PTO.
Bruce
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
2019 JCB 457 (A60462)
2007 Hyster S30FT 3,000lb. LP Forklift (A60352)
2007 Hyster S30FT...
SCREENER (A58214)
SCREENER (A58214)
2013 GMC Sierra Service Truck, VIN # 1GD422C84DF134632 (A61165)
2013 GMC Sierra...
STORAGE FEES (A59906)
