Liquid-filled tires...how much weight does it add? (figuring towing needs)
/ Liquid-filled tires...how much weight does it add? (figuring towing needs) #1
patchfarm
Member
Parsonsfield, Maine
None
Looking to buy a Mahindra 4110, which is about 3 hours from us, so it'll need to be towed. TractorData says it's about 4,000 lbs (assuming that's without the FEL?). So it has a FEL, and the owner says the tires are liquid-filled. He is unsure of how much weight that adds, nor does he know what the liquid is, as that was done by the first owner. Is there anyone who could give me a ball-park as to what the total weight might be with the loaded tires and the FEL? Just trying to figure out our towing needs.
Thanks.:thumbsup:
/ Liquid-filled tires...how much weight does it add? (figuring towing needs) #2
According to Rim Guard chart 14.9 x 24 tires add 500 lbs per tire.
/ Liquid-filled tires...how much weight does it add? (figuring towing needs) #3
Here is a link to a chart for number of gallons by tire size. Then of course multiply by the weight of the material in the tires. Rimguard and calcium chloride will be in the 11 lbs/gallon range. Antifreeze, water and windshield washer fluid will be in the 8 lbs/gallon range. You will need to extract a bit of fluid through the valve stem to determine the material used for ballast.
Liquid Tire Ballast Chart
/ Liquid-filled tires...how much weight does it add? (figuring towing needs) #4
The loader is 12 to 1300 lbs.
/ Liquid-filled tires...how much weight does it add? (figuring towing needs) #5
Roughly 6500 lbs with loader and filled tires. Too heavy for a typical 7000 GVWR car hauler, but just right for a 10k equipment trailer.
/ Liquid-filled tires...how much weight does it add? (figuring towing needs) #6
Do you know what a Mahindra 5035 with FEL and backhoe and filled tires would weigh? I have a 14,000 GVWR gooseneck trailer that I pull with a Dodge 2500 4WD.
/ Liquid-filled tires...how much weight does it add? (figuring towing needs) #7
Im not sure how much less than 14k, but Id guess in the 10k region. A 7520 with all 4 AGs filled, loader and B/H comes in around 13K.
larry
/ Liquid-filled tires...how much weight does it add? (figuring towing needs) #8
larry
After I posted, I did some research on TractorData, and I think you are right.
Tractor = 5386 lbs
FEL = 1450 lbs
Backhoe = 1487 lbs
Water in rears = 1216 lbs (19.4x24)
Total = 9539 lbs
I think you are close on your estimate of 10,000 lbs
/ Liquid-filled tires...how much weight does it add? (figuring towing needs) #9
Tractor = 5386 lbs
FEL = 1450 lbs
Backhoe = 1487 lbs
Total = 9539 lbs
If you go with Rim Guard or Calcium Chloride instead of water it will add another 250 lbs. Those numbers look good, 8300 lbs. without liquid ballast, 9500-9800 with ballast. It's a beast.
You ought to be ok with your 14k trailer. Assuming an empty trailer weight of about 4k, on the face of it you would assume a capacity of 10k for the trailer, but in many states you can actually get more as you can have 14k on your trailer axles and, depending on the truck, maybe 2k on the pin. So you ought to be just fine with a little to spare.
Let's get that tractor ordered. :)
/ Liquid-filled tires...how much weight does it add? (figuring towing needs) #10
This is not advice, do with the information what you want, it's your hardware and I'm not the safety police...
Keep in mind your trailer is rated for highway speeds with the impacts of bumps and potholes factored in. If you are not travelling at highway speeds, and travelling on good roads, your trailer can exceed it's rating with no harm done. I don't advise everyone to do it, but I've used a 7k trailer for moving nearly 8k around many times and never had an issue nor created excessive wear on the hardware. Load the weight evenly, don't travel fast or on rough roads, don't travel high speeds, don't travel long distances that could overheat the bearings, grease the axle bearings often. 3 to 4 hours at the rated limits or slightly beyond, travelling 40-45 miles per hour on good roads is not too much to ask of a good quality trailer that's well maintained in my opinion.
Two Boxes of Laptop Bags (A59317)
Two Boxes of...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
Byron 1514 (A60462)
Byron 1514 (A60462)
3PT Boom Pole (A60462)
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
