BX25 break in period
/ BX25 break in period #1
Kub39
Sorry for the mundane question that you have all already answered a gazillion times. And it may already be too late to ask since I have about 30 hours on the BX now. I have been running it between 2000 and 2600 rpms, occasionally adjusting the rpms so as not to run at the same rpm all the time. Is this ok or should I run it a little harder? After 50 hours is when I can throttle up most of the way, correct? Thanks in advance for repeating yourselves again. But I didn't see anywhere in the manual that discussed rpm and break in period.
/ BX25 break in period #2
Your engine was likely fully 'run in' at around 10 hours... There is not much to break in on any modern engine, tolerances a lot closer than they were decades ago, better materials and better assemblies.
At 30 hrs,You can use your engine at whatever load & RPM the job requires.
/ BX25 break in period #3
With 30 hours on it, I wouldn't worry about running it harder, I would still vary RPM's from time to time. I go by the manual, but certainly don't baby tractors during break-in.
I have seen lots of treads on break-in and opinions/practice vary widely.
/ BX25 break in period #4
...But I didn't see anywhere in the manual that discussed rpm and break in period...
Yea, the only thing it says is on page 26. A little more info would have been nice.
manual said:
OPERATING NEW TRACTOR
How a new tractor is handled and maintained determines
the life of the tractor.
A new tractor just off the factory production line has been,
of course, tested, but the various parts are not
accustomed to each other, so care should be taken to
operate the tractor for the first 50 hours at a slower speed
and avoid excessive work or operation until the various
parts become "broken-in." The manner in which the
tractor is handled during the "breaking-in" period greatly
affects the life of your tractor. Therefore, to obtain the
maximum performance and the longest life of the tractor,
it is very important to properly break-in your tractor. In
handling a new tractor, the following precautions should
be observed.
- Do not Operate the Tractor at Full Speed
for the First 50 Hours.
- Do not start quickly nor apply the brakes suddenly.
- In winter, operate the tractor after fully warming up the
engine.
- Do not run the engine at speeds faster than
necessary.
- On rough roads, slow down to suitable speeds.
- Do not operate the tractor at fast speed.
The above precautions are not limited only to new
tractors, but to all tractors. But it should be especially
observed in the case of new tractors.
Thanks. I must have skipped page 26 in all my excitement. But you're right, doesn't say anything about rpm.
/ BX25 break in period #6
I kept my BX25 a click under 3,000 rpms for the first 50 hours. I think running a motor too slow does more harm. They call it "lugging the motor": turning parts wear irregularly due to lack of speed/force.
/ BX25 break in period #7
I am wondering about minimum RPM for using loader and backhoe. Can you do harm by running too slow? What are recommended minimums? Rather not run my brand spanking new BX too hard for the first few hours. I have 1 hour on it! :cool2:
/ BX25 break in period #8
To be honest I never saw the point in running low RPM when using the FEL etc. during break-in, I ran it the same during that time as I do normally which is high enough to get good response. I am guessing it was generally around 2500 or so.
/ BX25 break in period #9
To be honest I never saw the point in running low RPM when using the FEL etc. during break-in, I ran it the same during that time as I do normally which is high enough to get good response. I a guessing it was generally around 2500 or so.
Me to.
/ BX25 break in period #10
Thanks RRR and JT. I am new to this game and just want to learn as much as possible in a quick time before I do something stupid. I know stupid will come but just trying to put it off for awhile. :confused3:
/ BX25 break in period #11
You are more than welcome, John has owned a bunch of those types of tractors and has helped me, do the search function and pull some of his old threads on maintenance etc., they are very easy to maintain and you will be surprised at how much you can accomplish with one, I have no experience with the back hoes, John has owned two.
You might also be interested in some of the modifications made by 4shorts and 94BULLITT.
/ BX25 break in period #12
Your owner's manual will recommend that you don't run at top rpm for the first 50 hours. I kept my BX25 a click under 3K rpm for the first 50. It's running fine, over 300 hours later.
/ BX25 break in period #13
Sorry Kub39... didn't mean to hijack your thread. I am excited about my new BX and glommed on to your post. Sounds like one should just use the thing, don't floor it, and take it easy with various speed for a while and don't worry about it!
Not to worry dragoneggs, I'm learning no matter what the discussion is. Got 48.3 hours on the tractor now. I've parked it and going to get filters and oil on Saturday for the first scheduled maintenance. It will be a fun day of greasing (for at least the 10th time) and cleaning it up nice and checking air filters. Then back into the yard for a couple hours of mowing.
/ BX25 break in period #15
Do your own Fluids and Filters on a BX - Page 19
You may want to go thru this thread before doing your 50 hour service or any of your service if your doing it yourself or even to see how easy it is for your dealer to do for the amount they are charging you and then you'll do it yourself.:laughing:
2011 Caterpillar 420E 4x4 Extendahoe Loader Backhoe (A64194)
2011 Caterpillar...
New/Unused Wolverine Quick Attach Coupler (A65583)
New/Unused...
2006 International 4400 Horton Emergency Truck (A64556)
2006 International...
2006 Chevrolet TrailBlazer SUV (A64557)
2006 Chevrolet...
2013 FORD F-350 SUPER DUTY (A65643)
2013 FORD F-350...
2024 JOHN DEERE TURF GATOR (A63276)
2024 JOHN DEERE...
