BEST CHAIN FOR CUTTING RR TIES??
   / BEST CHAIN FOR CUTTING RR TIES?? #1
saltbranch
Suggestions?
thank you
   / BEST CHAIN FOR CUTTING RR TIES?? #2
disposible
   / BEST CHAIN FOR CUTTING RR TIES?? #3
Chainsaw chain.
I find that log chains dont cut very well:laughing:
seriously, dont over think it. I cut ties and electric poles with just whatever saw I happen to grab. Worst think it can do is dull it out and you'll have to re-sharpen.
   / BEST CHAIN FOR CUTTING RR TIES?? #4
I've used whatever is on the saws at the time too. If I had a choice before starting, I would put on semi chisel for ties.
   / BEST CHAIN FOR CUTTING RR TIES?? #5
If the RR tie has dirt and rocks on it or in the cracks, I would be concerned. I would not cut in the spike area or at the ends if the steel S is in the end of the tie. If the tie is solid without cracks you should be good. You might consider a chain or blade that is already worn.
   / BEST CHAIN FOR CUTTING RR TIES?? #6
I would grab the oldest POS chain I had for cutting RR ties.
   / BEST CHAIN FOR CUTTING RR TIES?? #7
Any old chain I had, plus have lots of spare chains on hand.:2cents:
   / BEST CHAIN FOR CUTTING RR TIES?? #8
Use one that you're ready to toss anyway and grind the 'rakers' down a bit extra when you sharpen for the job. Brush a bit of #2 or kero on the bar & chain if they gum-up with creosote when cutting. Embedded gravel/sand will be 'the end' of the chain ...
   / BEST CHAIN FOR CUTTING RR TIES?? #10
Do not get the creosote on your skin. learned that the hard way as a teen whilst taking an old bridge apart.
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
2006 Tusk 500 PG-16 Forklift  3-Stage 188in Lift with Aux Hydraulics (A56436)
2006 Tusk 500...
Case skid steer wheels and tires (A56436)
Case skid steer...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
