X530 or X534??? Which one?
/ X530 or X534??? Which one? #1
FuntoMow
Connecticut
John Deere X300
I have 2 acres of which about 1.5 acres needs to be cut and the rest is wooded My back yard has a significant slope and then levels of at the bottom. I like the John Deere and have settled on the X500 series for now. Later, I will move up to the x700 series. Presently, I have a X300 which is good but it does slips when I turn into the hills.
I know the about the different models within the 500 series- My question is about the X534- Does it make that much of a difference? I have read there are some issues with attachments that do not fit as smoothly (i.e. triple bagger, tire chains- you need an adaptor and it will not take a tiller) I have also read it can tear up the lawn on tight turns, and that the deck shifts on an angle on turns for an uneven cut. I assume it depends on the user and terrain- however is it worth these problems? If we were to compare the X530 with the X534 after 2 years of use which would be more satisfying?
My yard has some obstacles but not many. I would like to use it to haul a cart and maybe push snow in the winter. First are there some issues with this design???? Second, Is the maneuverability worth the other issues ?
/ X530 or X534??? Which one? #2
...and that the deck shifts on an angle on turns for an uneven cut... ...My yard has some obstacles but not many... ...First are there some issues with this design???? Second, Is the maneuverability worth the other issues?
The deck does shift and it is especially noticeable with the 54" deck, the more slope you are on the worse it is. On flat terrain it does not seem to be a problem.
I do not see an "issue" with the design and from your own description of your yard "some obstacles but not many" I dont believe you need the 4WS.
My vote is for the X530. Actually my vote is for an X700 Series... then the X530. :D
Thanks for the information. The X700 series will come later.
/ X530 or X534??? Which one? #4
PM me if you have a chance...
/ X530 or X534??? Which one? #5
I considered both and decided on the x540 because of the power steering which I have been very pleased with. It does seem to spin at times when turning up a hill though. It does have the diff lock and better tires that seem to help greatly compared to passed tractors. The power steering may appear to be overkill but it well worth it in my opinion. I am presently looking into adding wheel weights which may solve some of the spinning issues. Hope this helps.
/ X530 or X534??? Which one? #6
Are you set on purchasing new? If not, maybe consider a pre-owned x585 (gas) or x595 (diesel)? I purchased an '03 x595 (300 hours) last month and am very pleased with the Yanmar diesel and the selectable 4WD. Very stout tractor.
Andreas
I will purchase used with low hours (under 150). The x585 / X595 or new x700 series are superior machines to the X500 and older GX/GT models. It seems everyone who gets the 4wd gets the diesel or vice versa in the X700 line. However, there is a big difference in price between the X720 and X748-even used- and if you are going to go for the X748 get the used 2305 SCUT or newer 1 series. Right now I have the X300 and it is acceptable but could be bigger and more powerful. I bought it used about a year ago.
Thanks for the idea I will check out the X585/595 and see the prices.
/ X530 or X534??? Which one? #8
I am receiving a new x530 in 2 days & are considering changing the front tires from 16x6.50x8 to 18x8.50x8 like on the x700.Thinking this will help it take the bumps better than our 325.Need your input.
/ X530 or X534??? Which one? #9
Don't own an X5xx Deere but I'll just point out that if you make the switch, you should make sure the your deck will clear the bigger tires. Also, I doubt it will change the ride much since the wheelbase is still the same.
