Rotary Cutter Raising Mower height via Drawbar modification
/ Raising Mower height via Drawbar modification #1
KnuckleDragger
The Heartland of America
I would like to just clip seed heads and the very tops of larger fescue clumps. I need my max height to be about 4 or so inches higher. I have been all over the mechanical make up of my older model Bushhog 2615 batwing mower. As far as I can tell, there is nothing on the mower itself that will get any more height than what the tractor's drawbar height will allow. I can go lower than the drawbar, but not higher.
Is there a safe modification that can be done to get a bit more out of the deal? I don't dare use a 3-pt draw bar with this tractor. The lever is a bit touchy and it is too easy to raise the 3pt above the PTO.
/ Raising Mower height via Drawbar modification #2
There are tractor drawbars available with a offset built into the hitch end. One of those would give you more lift and be safe also. Ken Sweet
/ Raising Mower height via Drawbar modification #3
Why not use the stupid little cuff things that limit the lift cylinders from retracting all the way? Or is that not tall enough?
/ Raising Mower height via Drawbar modification #4
290880809434
Above is a Ebay tem # of a set of New stroke control segments used to control the cylinder retraction. Ken Sweet
/ Raising Mower height via Drawbar modification #5
290880809434
That's it, could not think of the name.
stupid little cuff things = stroke control segments
/ Raising Mower height via Drawbar modification #6
Thanks all. An offset drawbar sounds like what I need. I wonder if I could weld up something myself just to attach to existing drawbar.
Stroke control segments are nice. I have a slow cylinder leak and I depend on them to keep from scalping as the cylinder retracts. Fully extended, I am only as tall as the draw bar.
