Rotary Cutter Raising Mower height via Drawbar modification
   / Raising Mower height via Drawbar modification #1
KnuckleDragger
The Heartland of America
I would like to just clip seed heads and the very tops of larger fescue clumps. I need my max height to be about 4 or so inches higher. I have been all over the mechanical make up of my older model Bushhog 2615 batwing mower. As far as I can tell, there is nothing on the mower itself that will get any more height than what the tractor's drawbar height will allow. I can go lower than the drawbar, but not higher.
Is there a safe modification that can be done to get a bit more out of the deal? I don't dare use a 3-pt draw bar with this tractor. The lever is a bit touchy and it is too easy to raise the 3pt above the PTO.
   / Raising Mower height via Drawbar modification #2
There are tractor drawbars available with a offset built into the hitch end. One of those would give you more lift and be safe also. Ken Sweet
   / Raising Mower height via Drawbar modification #3
Why not use the stupid little cuff things that limit the lift cylinders from retracting all the way? Or is that not tall enough?
   / Raising Mower height via Drawbar modification #4
290880809434
Above is a Ebay tem # of a set of New stroke control segments used to control the cylinder retraction. Ken Sweet
   / Raising Mower height via Drawbar modification #5
290880809434
That's it, could not think of the name.
stupid little cuff things = stroke control segments
   / Raising Mower height via Drawbar modification #6
   / Raising Mower height via Drawbar modification #7
Thanks all. An offset drawbar sounds like what I need. I wonder if I could weld up something myself just to attach to existing drawbar.
Stroke control segments are nice. I have a slow cylinder leak and I depend on them to keep from scalping as the cylinder retracts. Fully extended, I am only as tall as the draw bar.
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
2024 CATERPILLAR 306CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56438)
2006 Heil Tanker...
2015 Peterbilt 389 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2002 Bobcat 763 Compact Skid Steer (A56438)
2002 Bobcat 763...
