Miller 130 xp problem
/ Miller 130 xp problem #1
bh3zfc
ALABAMA
JD 5045E
Welder runs but when you start to weld it loses power and sounds weak. Any ideas
/ Miller 130 xp problem #2
I have a 130. Never had an issue.
I suggest you post this over on Millerwelds forum. Cruizer is a factory trained tech there who is real good. there are other good guys there who know these welders inside out too.
/ Miller 130 xp problem #3
I would check your supply voltage, just to make sure the AC line voltage is staying in spec. and not dropping.. other than that ???
/ Miller 130 xp problem #4
Could it be a wire feeding problem? Wire speed controls amps. If the liner is plugged and/or the tip damaged could cause it to seem to run cold. If the wire spool is too tight could also cause it. First thing is check to make sure you have consistent wire feed and a good ground. Also make sure you have the right size parts for the size of wire you have.
Nope. Guess the mixture on the bottle is not correct. Bottle is half empty
I turned the regulator down to 10 and it works like a dream.
2016 LEEBOY 8510C ASPHALT PAVER (A64279)
2016 LEEBOY 8510C...
Claas Lexion 500 Series Manuals (A63117)
Claas Lexion 500...
60in Bucket Skid Steer Attachment (A61567)
60in Bucket Skid...
2014 Wanco FD-304 Folding Solar Towable Arrow Board (A61572)
2014 Wanco FD-304...
Caterpillar 980F Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 980F...
Challenger 65E/75E/85E/95E Tractor Parts and Service Manuals (A63117)
Challenger...
