Buying Advice New B3350
/ New B3350 #121
I suspect you'll have that QA well before everything for the B3350 comes in, so be sure to take plenty of pictures when you get it! :) I'm still rather curious how different it is dimensionally to a standard SSQA. It would be nice to know how easy or how hard it is to modify standard SSQA compatible attachment to make them fit.
The good news is that I sold my B2620 today, so there's no looking back now at this point! I'm committed to buying the B3350 no matter what! :)
The salesman said a couple of weeks or so before it comes in. Hopefully he's right. I've got a Virnig rock bucket on order too - that is setup for " real " SSQA - so one of my first orders of business is going to be adapting that rock bucket to work on the Kubota QA.
Somewhere I've got the specs saved for the SSQA stuff - I was planning on carefully measuring the Kubota QA and comparing it to the real SSQA to see where the differences are. I hoping it's something simple and they only changed one dimension. I guess I'll know soon enough. I plan on taking a bunch of pics and posting it all - so I'll let everybody know how it goes.
/ New B3350 #123
to my eyes, it looked the same height and was more narrow.
If that is the case, I could see how it might be possible to modify the QA adapter to fit both Kubota and SSQA attachments (with the addition of wings.) Of course, this would depend on if the pins align.
/ New B3350 #124
When I measure across the bottom end of the loader arms on the LA504 on my tractor - I come up with (approximately) 31.5 inches
I have the Kubota pin-on style QA on the loader, if I measure across that (outside edge to outside edge) - I get approximately 32.5 inches.
Looking at the image of the dimensions on an SSQA (from this page: Will it Fit My Machine)
It basically goes like this for the dimensions on the SSQA: 44 inch max overall width.
Then the spacing for the lockdown holes is: | - 4" -| 2.5" |-2"-| ...........19" .............|-2"-| 2.5" |- 4" -| (totals up to 36")
Kubota LA504 FEL arms position (approx): ........| -- |.........................................................| -- |
There are slots at the 4" interval and the 2" interval. The standard lockdown position is at the 4" spot - the 2" spot is for older Case skidsteers if I understand correctly.
So the problem is that basically the LA504 loader arms - come down right in the middle (sort of off to one side actually) - on where the slot is for the lockdown
pin on the SSQA. Looking at the pics from the B50 series brochure:
http://www.toplinetrailers.com/documents/B2650B3350.PDF
It's sort of hard to tell where the lockdown pins are physically located - but it sort of looks like they're actually located right in front of the loader arms. Which means the Kubota might have lined up their lockdown pins - on the standard location. Hard to tell from the pictures. This is all just speculation - hopefully the parts come in soon and I will know exactly what's going on here.
/ New B3350 #125
Jim, all great information in your response.
For what it's worth, the Kubota B50 series video seems to show a bit more detail on the QA @ 2:06:
B50 Series Tractor - YouTube
Also, I put the deposit down on the B3350 today, so I just need to wait until everything comes in! :)
/ New B3350 #126
Thanks - just looked at that. It's hard to tell - because the video is shot from the side , but it does look as though the lock-down pins on the QA - are pretty much in line with the FEL arms . That is what Kubota would have to do - to get the lockdown pins to lineup with the spec'ed position of the slots
along the lower edge.
I edited my response #124 - my attempt at using text to illustrate the line-up between the LA504 loader arms and the SSQA lockdown slots - was not successful on the first try. Hopefully this is better.
/ New B3350 #127
That is the reason I had been reluctant to buy a universal SSQA, the more I looked at the dimensions of the loader and the locking pins on the adapter, it seemed they were almost inline but offset just a bit with each other, so the SSQA would have to be boxed with a plate and pushed forward more than I would like. I like Kubota's solution, it still pushes the bucket out a little further but not as much.
I think that yours will match up and with the universal SS attachements at least we are hoping so...
/ New B3350 #129
Someone posted a video of the B2650 with the LA534 loader and quick attach: KUBOTA B2650 CAB TRACTOR WITH LA534 LOADER - YouTube
Thanks for showing that. They didn't really zoom in on the loader QA that much - but right near the end they did get a halfway decent shot in passing of the lockdown pins on the QA - and they appear to be "outside" the loader arm. What that means is that it is possible that the lockdown pins at least - fall within the range to engage in the "standard" SSQA location (the 4" slots I detailed in post #124 ).
One of the responses earlier in this thread from Messicks indicated that the QA was non-standard. I guess we'll just have to wait and see what is non standard about it.
/ New B3350 #130
Yeah, that was my thought for posting it. The shot towards the end gave one of the best views I've seen so far of the locking mechanism. Agreed, it would be nice if the pins line up with the existing cut-outs (definitely make things easier to adapt.)
I'm hoping it turns out that it's just width issue. I think you could easily build a set of expansion wings on the outer edges without too much trouble. This would make it really easy to adapter standard SSQA attachments.
/ New B3350 #131
How about this:
https://www.youtube.com/watch?v=lLoa0MilEbQ
The person who uploaded the last B2650 video was kind enough to shoot another video at my request showing a close-up of the new quick attach system. How cool is that! :)
/ New B3350 #132
That looks to me to be a standard SSQA. Could be wrong but looks standard to me.:confused3:
/ New B3350 #133
How about this:
That's awesome. So it looks like the lock-down pins are located just outside the FEL arms. Which means (if you go back to the alignment picture I put in post #124) - that the lock-down pins should align with the standard location of the 4 inch slots from the SSQA standard.
looking at the video a few times and then going back to the SSQA measurements and trying to compare and I can't see anything that stands out that looks like it might not be standard.
It's been about ten days since I ordered - if I am to believe the salesman - I would expect the stuff to be coming in this week. I'm not sure I do (believe him that is) - but it would be nice to get a call before the weekend and get this ball rolling.
/ New B3350 #134
Agreed. Without measurements it's tough to tell from the video, but it does look fairly close to being standard.
Yeah, it does seem that way. Hopefully it will be in soon so you can take some detailed measurements of it! :)
/ New B3350 #135
The person who posted the video of the quick attach on the B2650 said it fits standard off-the-shelf SSQA attachments. This is really great news.
/ New B3350 #136
That is awesome news. I was envisioning being able to use SSQA configured attachments - but after doing some sort of mods to them. If they'll fit without mods - that's great.
I just got a call this afternoon that the Virnig rock bucket that I ordered a few weeks back - should be arriving next week. Still waiting to hear if the QA has shown up yet at the Kubota dealer - hopefully that will show up by next week also.
/ New B3350 #137
Uh... they are wrong. To someone with an untrained eye, its very easy to look at it and assume but its too narrow.
We'll probably look at building blank for the coupler or a filler plate to see if we can make it work... that will be a winter time project.
/ New B3350 #138
That was my thought too after seeing some of the pics - it looks like the lockdown pins actually line up with the spec on where the slots are - but the coupler itself (the part that's on the FEL) - is narrower than the SSQA standard - so it would be "floating" if you tried to hook it up to an attachment that met the SSQA standard.
Of all the potential problems - at least that is an easy one to fix. If Kubota had no met the standard in some other dimension - that would have been a harder problem to adapt to.
/ New B3350 #139
If you notice the top part of the QA is quite a bit wider than the loader arms. I am betting it is a SSQA.:drink:
/ New B3350 #140
I'm not arguing that this could be indeed narrower than a standard SSQA design (since I haven't seen one in person and I'm only going off the pictures/video), but I'm struggling to see where it differs in width. With those extensions at the top of the QA, it looks nearly identical in size to several others that I've compared it to.
Not only that, but the Kubota bucket also looks like it should work with standard SSQA compatible loaders. It would nice to have actual measurements on it to finally but this to bed! ;)
Water Tank (A61570)
Water Tank (A61570)
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A62129)
2020 CATERPILLAR...
2018 Ford Escape Multipurpose Vehicle (MPV), VIN # 1FMCU0F70JUB03642 (A61165)
2018 Ford Escape...
2001 Sun Coast Trailers T/A Enclosed Trailer (A61569)
2001 Sun Coast...
2025 SDLANCH IRET13 Electric Tricycle (A60352)
2025 SDLANCH...
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A61568)
2017 Autocar...
