tc45d will not turn over
/ tc45d will not turn over #1
haiku
tc45d was running fine-stopped to repair mower now will not start-traced wires as best I can (inexperience)-
have power on white wire to operators safety modulebut nothing on other side blk or brown could this be the culprit ? or ?-starter will not turn over help need to move tractor -thanks
/ tc45d will not turn over #2
Is trans in neutral & pto lever in off position? Have you checked ALL FOUR battery cable connections for cleanliness & tightness???? Have you checked battery voltage?
trans is in neutral & pto lever is in off position -I have checked cables at battery & cleaned (2)--are the other two youare referring to at start-I will check those now-thanks for response-
/ tc45d will not turn over #4
Any luck--
I have on occasion had my nuetral safety switch connection come unplugged. Had a no start. The connection was on the left side just under the step.
Tharin
Any luck--
Tharin
No luck so far-getting pretty frustrated ( I temporarily jumped nutral safety swich as a test) -I believe that lets power to safety module (?) &
from there if module is working to starter-but I don't really know-any other ideas-i.e could it be ignition switch? (how to test ? ) -or?
2009 Caterpillar 345D Hydraulic Excavator (A64553)
2009 Caterpillar...
Portable Chicken Coop (A66408)
Portable Chicken...
12ft. 24 Gauge R Panels (A65640)
12ft. 24 Gauge R...
2004 INTERNATIONAL 7400 20FT T/A FLAT BED (A59914)
2004 INTERNATIONAL...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
1999 GROVE MZ66DXT TELESCOPIC BOOM LIFT (A65053)
1999 GROVE MZ66DXT...
