tc45d will not turn over
/ tc45d will not turn over #1
haiku
tc45d was running fine-stopped to repair mower now will not start-traced wires as best I can (inexperience)-
have power on white wire to operators safety modulebut nothing on other side blk or brown could this be the culprit ? or ?-starter will not turn over help need to move tractor -thanks
/ tc45d will not turn over #2
Is trans in neutral & pto lever in off position? Have you checked ALL FOUR battery cable connections for cleanliness & tightness???? Have you checked battery voltage?
trans is in neutral & pto lever is in off position -I have checked cables at battery & cleaned (2)--are the other two youare referring to at start-I will check those now-thanks for response-
/ tc45d will not turn over #4
Any luck--
I have on occasion had my nuetral safety switch connection come unplugged. Had a no start. The connection was on the left side just under the step.
Tharin
Any luck--
Tharin
No luck so far-getting pretty frustrated ( I temporarily jumped nutral safety swich as a test) -I believe that lets power to safety module (?) &
from there if module is working to starter-but I don't really know-any other ideas-i.e could it be ignition switch? (how to test ? ) -or?
John Deere Van Brunt 10' x 7' Grain Drill (A66285)
John Deere Van...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
MERRITT ALUMINUM HEADACHE RACK (A64277)
MERRITT ALUMINUM...
John Deere 12ft pull-type cultimulcher, Orion, IL (A65640)
John Deere 12ft...
2022 EZ-GO ELITE...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
