What shear bolt grade would you recommend?
/ What shear bolt grade would you recommend? #1
Henri88
Northern N.B.
2008 JD 2305, 1000hrs
New to brush cutting. I have a new to me Howse 4' rotary cutter and a 2305 JD with 18hp pto. The Howse manual recommend grade 5 or lower so my choice is either 5 or 2. I am leaning more towards the grade 2 but I'm worry that the shear bolt would be prone to shear easily. Your thoughts.
I will be using it on a 1 1/2 acre with mostly grass, but we did cut some Hawthorn and apple trees. I also know all about the slip clutch but would like to stick with the shear bolt if possible.
Henri
/ What shear bolt grade would you recommend? #2
Henri
I would start with the safe bet, and use a grade 2. If it proves to be unworkable, then go to a grade 5.
Tx guys! Does shearing a bolt while bush cutting a common thing. Sorry but I am completely green to this activity. :eek:
/ What shear bolt grade would you recommend? #5
I just faced that with my Agrisupply PHD. The manual says grade #5. I bought a handful of #2's. I figure break $5 worth of bolts is better than $100 of PTO or $300 of PHD.
/ What shear bolt grade would you recommend? #6
I wouldn't be worried about running grade 5 bolts. At CNH (and I would assume Howse is the same) components are engineered based on grade 8 shear bolts with the assumption that someone will attempt it. I'm used to property where shearing bolts on plows and bush hogs is common, so I'd vote grade 5.
/ What shear bolt grade would you recommend? #7
What i have done also is if a grade 2 is to soft, get a grade 5 one size smaller.
I'm not to worry about the implement, it is the pto on the tractor that worry's me the most. As mention above, I'm going with grade 2, but I just don't know how frequent a shear bolt will brake under normal (brush cutting) use. Maybe I'm over worrying here, but I was kind of hoping that someone with pretty much the same set-up would chime in. Maybe I should've ask my question on the JD forum since it is not the implement but mostly the tractor that I worry about.
Arcking, what size is your cutter and tractor? Tx
Henri
/ What shear bolt grade would you recommend? #9
I usually break things with a 55hp tractor and 10ft bushog...a little different scale than you're talking. I've never sheared a PTO bolt other than on a round baler though - usually it's the rough ground that shears other bolts. Not saying it isn't rough on the equipment, but if I were to use lower grade bolts I'd never get anything done.
Tx Arcking! :)
2007 Volvo VNL Truck Tractor (A61307)
2007 Volvo VNL...
John Deere HX20 (A60462)
John Deere HX20...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
200 Gallon Tank (A57148)
200 Gallon Tank...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 24in Digging Tooth Bucket Excavator Attachment (A60352)
John Deere 24in...
