MX6 Rear Wheel Height Setting
/ MX6 Rear Wheel Height Setting #1
econometrics
East Texas
Deere 5075E MFWD OOS w/PR, 540E; Gator 825i
Howdy all,
Any of you guys running your MX6 shredder with the rear wheel down as far as it can go (raising the rear of the cutter as high as it can go when cutting)?
I'd like to cut my smaller side pastures a little higher this year before summer sets in, and wanted to see if anyone else had mowing experience on the highest setting.
Thanks
/ MX6 Rear Wheel Height Setting #2
Howdy all,
Thanks
I run mine like that most of the time. Cuts about 8 inches IIRC.
Good to know. That's about the cutting height I'm trying to achieve.
/ MX6 Rear Wheel Height Setting #4
I looked into adjusting mine once and couldn't determine how to get it to move to another location and the bolt line up. Think it is around the middle position now. I just use the 3pt lift to adjust the height. Can get it almost lawn mower short or raise higher for rougher areas.
They really are a bear to adjust. I had to beat on the two rear brackets with a rubber mallet to get them to a place where the bolt could line up through the holes.
2020 International LT625 Sleeper 48 (A62613)
2020 International...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
UNUSED RAYTREE RMLL60-60" HYD POWER RAKE LAND LVL (A62131)
UNUSED RAYTREE...
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
2021 John Deere 6110M Tractor (A63109)
2021 John Deere...
