Were is "Barrel Ballast Started"
/ Were is "Barrel Ballast Started" #1
Xfaxman
Super Star Member
Guthrie, OK
Toolcat 5610 G - Bobcat V417 - TORO+Loader
I was following the thread by Dan Hunter in this forum, now when I click the link in my email notification I get:
Message
Xfaxman, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, your account may be awaiting activation.
If you believe you are receiving this message in error, please contact us through the link below.
TractorByNet.com - Compact Tractor Forum When I click this link it takes me to the FORUMS page, with all the forums listed.
Here is the link that is in my email:
http://www.tractorbynet.com/forums/showthread.php?t=270823&goto=newpost
Dan did you finish building it?
/ Were is "Barrel Ballast Started" #2
Got me but it just did the same when I clicked it.
/ Were is "Barrel Ballast Started" #4
Barrel Ballast Finished! It'll sit in the driveway for a week and then go out to the ranch. I put a bunch of rebar in it. To fill it, I put the mixer in the bed of the truck and was able to dump directly into it...twelve 80 pound bags.
BTW, I asked the admin to ax the thread when, like so many times on this site, it began to weave off topic.
Congratulations, looks like a gooder-un. :thumbsup:
Thanks for the update on both things.
/ Were is "Barrel Ballast Started" #7
Well, it made it to the ranch. The photo doesn't show the 8 straps I put over and around it. Picking it up with the tractor was interesting. It clearly is heavy - 960 pounds of concrete alone. Finally, I can get out and start decimating the red cedar with the tree sheer.
/ Were is "Barrel Ballast Started" #8
I received the same identical message yesterday when I attempted to go on another thread.
Glad to know it isn't just me. I received the same message on a thread I had posted on this morning, when I clicked the link to view it this afternoon.
That message shows up when trying to go to a thread that has been removed by a moderator.
Sounds good, need pictures on the tractor.
What kind of tree shear? I broke a blade on mine and am looking to replace it.
/ Were is "Barrel Ballast Started" #11
Thank you kindly, Xfax!
/ Were is "Barrel Ballast Started" #12
Nice job, great idea !!
/ Were is "Barrel Ballast Started" #13
ASAP but it won't look so sharp...blue against green/yellow. It's an M&M tree snip and it's massive at 800 pounds not including the 4' brush guard. I couldn't imagine breaking a blade on it. I'd sure like to know how you did it so I could avoid it myself.
The blade broke because it was not correctly repaired when the brace on one blade was rewelded by the manufacturer, when the original weld cracked on that blade.
It is an old three point cedar tree cutter that I mounted with some flexibility on a fork frame to use on the V417.
This is where the blade broke.
I was cutting a 10" diameter Oak tree, right next to another big tree. About half way through the cut, the end of the blade on the right came against the other tree, and quit moving, the blade on the left broke.
The manufacturer told me it was 1080 hard steel, they don't use it now, don't have any, can't get any, can't fix it.
/ Were is "Barrel Ballast Started" #15
I couldn't use the shear without it. I can't tell it's there most of the time though occasionally it gets used as a bumper. Half my neck is fused and I don't look behind me that much.
/ Were is "Barrel Ballast Started" #16
dan try a machaine shop to make you a new one blade for the shear
I have called two places, but haven't had the time to load it up and take it in to be looked at.
/ Were is "Barrel Ballast Started" #18
Whoa, I spy a bent cylinder rod ?
Good eyes! :thumbsup: Look closer and you will see the hydraulic hose connector is broken also.
/ Were is "Barrel Ballast Started" #20
Very nice! I'm thinking of making one of these myself. What size square tubing was used? What are the dimensions on the triangles?
CAT 930 60" Forks (A68134)
CAT 930 60" Forks...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2016 CAT 308E2CR EXCAVATOR (A67714)
2016 CAT 308E2CR...
PORTA POTTY (A68842)
