Were is "Barrel Ballast Started"
   / Were is "Barrel Ballast Started" #11
Thank you kindly, Xfax!
   / Were is "Barrel Ballast Started" #12
Nice job, great idea !!
   / Were is "Barrel Ballast Started" #13
Sounds good, need pictures on the tractor.
What kind of tree shear? I broke a blade on mine and am looking to replace it.
ASAP but it won't look so sharp...blue against green/yellow. It's an M&M tree snip and it's massive at 800 pounds not including the 4' brush guard. I couldn't imagine breaking a blade on it. I'd sure like to know how you did it so I could avoid it myself.
The blade broke because it was not correctly repaired when the brace on one blade was rewelded by the manufacturer, when the original weld cracked on that blade.
It is an old three point cedar tree cutter that I mounted with some flexibility on a fork frame to use on the V417.
This is where the blade broke.
I was cutting a 10" diameter Oak tree, right next to another big tree. About half way through the cut, the end of the blade on the right came against the other tree, and quit moving, the blade on the left broke.
The manufacturer told me it was 1080 hard steel, they don't use it now, don't have any, can't get any, can't fix it.
   / Were is "Barrel Ballast Started" #15
I couldn't use the shear without it. I can't tell it's there most of the time though occasionally it gets used as a bumper. Half my neck is fused and I don't look behind me that much.
   / Were is "Barrel Ballast Started" #16
dan try a machaine shop to make you a new one blade for the shear
I have called two places, but haven't had the time to load it up and take it in to be looked at.
   / Were is "Barrel Ballast Started" #18
Whoa, I spy a bent cylinder rod ?
Good eyes! :thumbsup: Look closer and you will see the hydraulic hose connector is broken also.
   / Were is "Barrel Ballast Started" #20
Very nice! I'm thinking of making one of these myself. What size square tubing was used? What are the dimensions on the triangles?
Barrel Ballast Finished! It'll sit in the driveway for a week and then go out to the ranch. I put a bunch of rebar in it. To fill it, I put the mixer in the bed of the truck and was able to dump directly into it...twelve 80 pound bags.
BTW, I asked the admin to ax the thread when, like so many times on this site, it began to weave off topic.
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
Wolverine 72" Skid Steer Bucket (A50515)
Wolverine 72" Skid...
(INOP) 2003 HAULOTTE OPTIMUM 1930E SCISSOR LIFT (A51243)
(INOP) 2003...
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
UNUSED AGT DM20 EXCAVATOR (A51243)
UNUSED AGT DM20...
