Ballast Box Upgrades
/ Ballast Box Upgrades #1
Tim13
Member
Indiana
JD 3320 w/ 300CX FEL
I'm looking to add a ballast box and make a few upgrades to make it as versatile as possible. I'll be using it on a JD 3320 w/ iMatch.
I'm leaning toward just buying the box from Deere and having the local welding shop make the changes I want.
In the image below I've mocked up some ideas based on the fantastic builds and pictures I've found on this site. Let me know what has worked for you or maybe what you would do different.
Inside the box was going to add two (3 if they'll fit) pipes to hold shovel, rake, chain and a slot to hold my chainsaw.
On the back was planning to add two 3/8 grab hooks near the top and two clevis mounts toward the bottom and then a trailer hitch receiver at the bottom center.
/ Ballast Box Upgrades #2
Here is my counterweight, that I built from steel scrap. I want to add more weight, and a chain basket, and maybe a tool holder. I think it's around 800#. I decided to use steel because it would be more compact.
/ Ballast Box Upgrades #4
A lot of the guys here have done just what you are planning but I have a different take on it. I don't care much for the idea of leaving an air pocket in my ballast box for tools. I would rather have portland cement for ballast inside the ballast box and weld the tool holders on the outside of the box.
/ Ballast Box Upgrades #5
Tim, I'd agree with bigtiller, but for a different reason. If you leave this attachment outside the tool holders and chainsaw holder are going to fill with water. Not a pretty place to stick the bar of your chainsaw into. By mounting on the outside you can create drain holes.
I'd also add a chain box.
Keep us posted on your progress!!!
/ Ballast Box Upgrades #6
I don't like the idea of using concrete, since it's permanent! So I used scrap metal, including some lead in my JD box.
I put a 2" receiver tube under the box with 2 RR rail skids. Tool holders are on the outside of the box with a metal tray about 8" down inside for chains & tools. Total weight is 630#, just over the recommended (for my 790) 618#. Everything is bolted on so they can be changed if needed. ~~ grnspot
/ Ballast Box Upgrades #7
View attachment 312581View attachment 312582View attachment 312583
Some great ideas! :thumbsup:
AKfish
Thanks for the good ideas. Spoke with local welding shop and they can make a box for $350 using 3/16 steel. It'll be $100 more than the JD box but will definitely be solid. Am I spending unnecessarily?
I really like the idea and pictures of placing the tool holders on the outside and will incorporate that into my design. GRNSPOT110...What are you using to hold your chainsaw?
Also, anyone using hooks on their box to pull shrubs or are you attaching chain to the back of your tractor?
Your input is really helping this come together.
/ Ballast Box Upgrades #9
Layered 1/4" sheet plastic, sandwiched together!
That way, the chain only touches the plastic! ~~ grnspot
/ Ballast Box Upgrades #10
Good Point. I built a scabbord out of light metal. Then realized I can't drop my saw bar in there without dulling the chain. So I widened it to hold the saw with a plastic bar cover on it. Works, but sometimes when I pull it out I get the bar cover too, which always aggravates me.
/ Ballast Box Upgrades #11
Having a box allows you to change the amount of weight easily. If that's what you want then no, your not spending unnecessarily. If you don't need a box, and can use just a weight like mine, it may be cheaper depending on what kind of junk your welder has lying around. I assume he would be buying the 3/16' stock, so you would be paying "new metal" price. He may only charge you scrap price for otherwise useless pcs. he has lying around.
With my design, it isn't hard to increase the weight, just weld on more scrap. I now have a larger tractor, so I do intend on adding some.Reducing the weight however would be a PITA. Cement blocks are pretty fixed also.
I never put chain hooks on my weight. If I want to tow something I connect using the 2" receiver with a ball or shackle. Hooks arn't a bad idea though. I think they would be handy. If I was going to pull shrubs I would use the drawbar.
Bill
/ Ballast Box Upgrades #12
Bill
I don't have any pics now, but I built a weight box using worn out grader blades which are pretty heavy. Designed it so tractor suitcase weights can be racked. Need more weight, add more suitcases, need less, remove some. Also serves as a great place to store my suitcase weights I use on the front of the tractor when the loader is off. I take no credit for thinking that out. Just kinda happened.... :)
As I continue to research and learn I'm noticing that 99% of the ballast boxes I see do not have any pulling capabilities with the exception of a tow receiver. (I have seem some heavy hitches with clevis shackles.) The concern seems to be that pulling is designed for the drawbar which keeps the weight low. Since a 3PH is capable of many tasks including dragging a plow, is it equally capable of pulling shrubs and logs and such as long as I keep the weight low? Or am I going beyond that which is necessary? Would hate to pull the BB apart!
/ Ballast Box Upgrades #14
I think the problem with pulling stumps with the 3PH is that it's in float, with no down pressure. If the front wheels come off the ground the 3ph will go up too. The drawbar is in a low fixed position and would tend to keep the front end down. This would hopefully prevent a flip.
I'm sorry if I have done a poor job explaining how this works.
I put a hitch on my counterweight so that I could move my trailer, or drag my chain harrow without having to remove the weight. Things that are well anchored to the ground I generally try to dig out with the loader.
I have a stump bucket for stumps (duh) and rocks. Brush or bushes I usually remove with a rock bucket, or the standard loader bucket.
Bill
/ Ballast Box Upgrades #15
I can only relate from the two tractors I have but after replacing the rockshaft seals ,you get a good look at the top of the 3 points internal construction , and although fairly strong it is in no way as strong as pulling down low and more solid mounting thru the lower arms and stablizers , at a minimum
plus if your tractor employs draft control are you willing to load test that part of your rockshaft ,when towing or pulling a (shock load) is not out of the question. pulling really should be done thru the
tow bar or some thing that applies the force thru the part of the tractor designed for it down low if you mount it high it will put the force thru the top link and rockshaft -draft control my 02 cents
/ Ballast Box Upgrades #16
Not sure if you guys have seen this but based on most of the talk being about flexibility, it may meet your needs with the 72# suitcase option. No affiliation with the company just have been doing a lot of research for myself. http://heavyhitch.com/
/ Ballast Box Upgrades #17
Not sure if you guys have seen this but based on most of the talk being about flexibility, it may meet your needs with the 72# suitcase option. No affiliation with the company just have been doing a lot of research for myself. Compact Tractor Attachments & Lawn and Garden Tractor Hitches
Interesting idea and very flexable. I like the fork attachment. The only down side I see is the cost of weights. If you have a small tractor and use suitcase weights now it should work great.
Bill
/ Ballast Box Upgrades #18
Bill
So all the creative energy can now be spent making weights in a configuration that hang on this. :)
/ Ballast Box Upgrades #19
Some great ideas here.......I have a small tractor....needed some weight in back.....added ballast by taking an old washing machine tub....running a bar through it and filling it with rocks. The tub drains well because of all the holes.....guessing it weighs about 300 lbs. Easy to put on and remove. I don't do any pulling with it. Cheap solution to my problem. Don't have a picture.....good luck!:thumbsup:
/ Ballast Box Upgrades #20
Speaking of flexibility, this one had the most options when I was looking, notice the receiver at the top.
The Carry All on top.
The Carry All on the bottom.
They have one for suitcase weights.
More options here. OMNI Mfg LLC
2005 Fontaine FTW5-8048SLW 48ft. 38 Ton T/A Piggyback Flatbed Trailer (A61573)
2005 Fontaine...
Bomag Roller (A63689)
2005 Toro Z Master Commercial 72in Zero Turn Mower (A61572)
2005 Toro Z Master...
2013 CATERPILLAR 305E CR EXCAVATOR (A64279)
2013 CATERPILLAR...
2014 John Deere 310SK 4x4 Extendahoe Loader Backhoe (A61572)
2014 John Deere...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
