Greetings from TN
/ Greetings from TN #1
jeretp
cunningham, tn
ford 3000
Just joined after I bought a "70's model Ford 3000 diesel. As soon as I began to run it at home it died after 10 mins of use. I let it cool off and it started again. I thought that it might be trash in the fuel. After running it for 10-15 mins each time, it continues to die out, and now the RPM's will rev up just before it dies out. So, I thought I better look for some advice on the internet, and wound up here. I am thinking that I will take it to the mechanic tomorrow, but will be embarrased if its simply a filter. Thanks for giving the opportunity! JP
/ Greetings from TN #3
I'd make sure the fuel shut off is opened it is on the right side by the back of the fuel tank (mine leaks thru some fuel even when shut off... counterclockwise is open,
just a thought- don't ask me how I know this can happen, it is also possible this is not your problem but I would check this first..
/ Greetings from TN #4
:salute:Welcome from Ohio
/ Greetings from TN #6
Greetings and Welcome to TractorByNet :tractor:
/ Greetings from TN #7
Welcome!
/ Greetings from TN
Thanks to all. I Enjoy looking around here and look forward to being a member.
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
UNUSED KJ 20' BI PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20' BI...
2016 Boxer 700HDX Compact Skid Steer (A63116)
2016 Boxer 700HDX...
2023 John Deere 6120M Tractor (A63109)
2023 John Deere...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
BOSS 990 Fuel Trailer - 990 Gallon Farm Diesel Tank, Field Refueling Solution (A63118)
BOSS 990 Fuel...
