2013 Terex PT110 Forestry
/ 2013 Terex PT110 Forestry #1
ALittleDirtWontHurt
VIRGINIA
Gyrotrac GT-25, Terex PT110 Forestry, New Holland TC33, Kubota KX080, Terex PT30, Rayco C140, Polaris ATP 500
Took delivery of the new machine today and had a chance to put it in the woods for a few hours. So far a night and day difference (and improvement) over the old PT100. 45 GPM and a hyd. driven cooling fan really makes a difference. Waiting to see if any of the demons from the older PT's will surface, but so far I think it's a solid machine. It seems they really worked out the old bugs.
/ 2013 Terex PT110 Forestry #3
I have exact same set up. I have 100 hrs on mine. Only problems so far...1 air conditioning not working while under load....2. Watch your air conditioning bracket that holds the condensor, mine broke pulling condensor torwards radiator, i caught it in time, but bracket is held on by 3 screws that need to be grade 8 and locktighted in due to vibration.... And ohhh ya, the windshield wiper wont last long lol
/ 2013 Terex PT110 Forestry #5
The A/C bracket breaking is not new and was a big problem on PT100Gs too. I have a buddy who works for a large right of way clearing company near me and they finally had their own brackets made because Terex would not acknowledge that the failures were a problem (They won't consider buying until they've been out for awhile..they were told that Terex only ran one test machine for both dirt work and brush cutting, and then for a very short time before the launch). Hopefully they'll address this. Local dealer has also heard that they've had problems with the fans (may need to replace) and something to do with the motor mounts as well. Might want to contact your local dealer.
/ 2013 Terex PT110 Forestry #6
Well all i can say is terex replaced bracket over night no questions asked. I owned a 4810 so i am aware of the history, and believe me i was hesitant to buy, but the machine does perform, has better balance than the 299 as well as cleanout access. If it is as durable as my takeuchi has been i will be happy. I'm not drinkin the coolaid, but with my cimaf head it does volumes above comparible machines and the low ground pressure is a plus. I demoed a sk140 and while it was a monster it will not outwork the terex by much and the price difference was HUGE....
/ 2013 Terex PT110 Forestry #7
I have no question that hydraulically it will outperform any of the other OEM CTLs right out of the box. You will see from my previous posts on this site that I like the ASV machines; I own a RC50 and it has been extremely good to me.
I am not a big fan of Terex, and I feel they have hampered any kind if innovation that comes out of their ASV factory. I personally don't think Terex is really committed to construction. This is only based on what I see out of my windshield, what I see on forums and what my buddies who sell Terex tell me. They don't test machines adequately (dealer conversation), they have jacked up ASV parts pricing to obscene levels, their new backhoes are average at best, their skid steers are a poor attempt at getting into the market (what was Takeuchi thinking????) and they are essentially out of the mini excavator market based on the prices they are asking for a solid yet very antiquated Schaeff machine.
I hope you have great luck with it.
Ran four hours yesterday and had a small electrical problem that caused the cooling fan to shut off ('fwd fan solenoid fault'), but my dealer took care of it quickly and it's back in action. All in all, I'm impressed with the machine. I'm still getting debris in the engine compartment but Terex designed the belly-pan to drop outwards so it's much easier and faster to routinely clean out.
/ 2013 Terex PT110 Forestry #9
Have they inproved the u/c? Other than the ride, I've never heard a good comment about them.
I always liked the undercarriage style. Never had a problem with it out in the woods. Replacement is expensive, but I just factor that into my pricing. The new design is totally open, which is better to keep clean of debris. In addition the inner rollers articulate. Rubber bushings allow the movement, but I'm not sure yet how much life to expect out of that design before replacement. Supposedly, they say this extends the life of the overall undercarriage. The older rail style they had before were much harder to clean out plus if you traveled over something hard or uneven it would put more weight of the machine in that one area. I believe the RC's had a thinner rail (which was prone to breakage), and the PT thickened the rail. Another thing that was done on the new was to totally enclose the area where the drive hoses met the machine chassis as to eliminate debris entering through the bottom.
Day two running........blew the forward drive hose (the one inside the belly pan) running the right track. Effectively the machine would only turn right going forward, but would back up fine. After dumping gallons of fluid and making a huge mess, managed to get it up on the trailer and back to the dealer (and of course breakdowns happen most on the weekend). It'll have to be fixed the on the trailer, because she darn sure isn't driving forward. Better there though than in the middle of the woods. Two days running a brand new machine.....broken down each time, but I'm not discouraged with the machine yet. Chalking this one up to breaking it in.
/ 2013 Terex PT110 Forestry #16
What does that unit run in cost.
What gradient slope can it tolerate and what size CWD can it deal with?
/ 2013 Terex PT110 Forestry #17
Well according to the salesman, it does not cost enough, there is no gradient on this planet it wont operate on easily, and will chew 12" diameter material like we chew on toothpicks... Lmao all kidding aside i have not had it on extreme slopes and cost should be less than 90 k .... Not sure what cwd is
/ 2013 Terex PT110 Forestry #18
CWD -coarse woody debris. Must be a term that we use out here that you don't use where ever you are. Can refer to anything from small stuff to logging residue of size that might take a decade to decay back into the environment. You answered my question w/o knowing it anyway, 12 inches , not too bad. Thanks.
The hydraulic failure ended up being some kind of equalizing line between the two motors. It was a steel line that had to be replaced. Back out tomorrow for day three. Crossing my fingers.........
/ 2013 Terex PT110 Forestry #20
Ouch! Sounds like you're off to a rough start with the new Terex.
I had the same kind of luck with the 2011 PT-100G I bought. Did your dealer pay for the hydraulic fluid?
I just couldn't stand the payments of a new machine, and the down time of an old one. I sold mine at a loss to get out from under it.
I hope your luck improves, and your dealer is a really good one.
Andy
2009 Case CX240B Excavator (A64194)
2009 Case CX240B...
2025 Wolverine GB-11-72W 72in Dual Cylinder Grapple Bucket Skid Steer Attachment (A66734)
2025 Wolverine...
2008 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2008 FORD F150...
2006 PETERBILT 379 (INOPERABLE) (A67714)
2006 PETERBILT 379...
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
Unused 2024 Land Pride PF1242 42. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
