Flail Mower Brush Removal Strategy
/ Brush Removal Strategy #1
1026R owner
Northern New Jersey
John Deere 1026R
Hi Gang!
I have a meadow of about four acres surrounded by wooded wetlands, some of which is edged with thorny bushes I would like to eliminate. I'm fairly certain this is some sort of invasive alien plant, possibly multiflora rose. I want to get rid of this and replace it with native bushes, trees, wildflowers and grasses that provide food for us as well as food and cover for turkey and birds and nectar for bees and butterflies. Also, there are a lot of vines growing all over the trees at the edge of the woods that I will be snipping. I'm considering several ways to do this, each of which involves purchasing equipment that will find other uses down the road. So which method is best and what should I buy? Burning isn't allowed here.
I've cut some of it with a small chainsaw, but the lighter stuff and vines grab at the saw and crawling around and under the thorny bushes isn't ideal.
One thought is to buy a handheld brush cutter, similar to a string weed trimmer but with a rotary blade and bicycle-like handlebars. Echo, Stihl and others make them, though they are not readily available at the big box stores, possibly because you could cut your shin in half with one.
Once everything is cut down, I could let it rot down or, preferably, grind it up in a chipper/shredder and either blow it in a shallow pit or hot-compost it to kill the seeds. I would need to get a chipper/shredder or chipper, which would be useful to have.
Another thought is a field and brush mower such as that sold by DR. They have a tow-behind version that should work well on our John Deere 1 Series subcompact tractor or on our Yamaha Rhino ATV. It has its own gas engine. DR claims its mower will chop and mulch the material. I could use such a device for blazing and maintaining a trail we're building through 40 acres of woods.
Similarly, John Deere has a flail mower. I have not priced it but am guessing it's the most expensive option. I believe it's a three-point hitch setup. Either the flail mower or the brush mower could be later employed to mow nearly two acres of wildflowers we are planting in the meadow.
Another thought is to scoop the bushes up with my little backhoe, though I'm not sure it has the guts to scoop up one of these bushes, some of which have strong, deep root structures.
Equipment I already have: backhoe, front loader, box blade, tiller, chainsaw, chains (for yanking), Roundup.
Thoughts? Suggestions?
/ Brush Removal Strategy #2
Depending on the quantity a walk behind brush mower like the DR you referenced or a brush hog for your tractor would seem to make the most sense. The brush hogs basically splinter the stumps and depending on the plant species can prevent regrowth. Just cutting them off with a brush cutter leaves a smooth stump that likely will grow back unless you treat the stump with a sprayed on brush killer.
/ Brush Removal Strategy #3
/ Brush Removal Strategy #4
Greetings Bush Man in NJ:
I'm the master of jungle clearance in the Islands. Your problems pale compared to those in the tropics. For starters, I assume your ground is somewhat level. You already have an advantage there.
Some areas can be mastered with a bush hog, a rough cut rotary mower. If you make continued passes over even determined trash trees and vines, eventually the root system gives it up. In my case, I need to remove trash trees on sharp slopes. To do this I have a four inch diameter poly rope 30 feet in length, a 3/8 chain with grab hooks 20 feet long and....
BrushGrubber | Home
I use the biggest trunk grabber they make due to the fact that I need to jerk TanTan trees with diameters approaching 6". The company offers a range of root pullers for problems small to large. Included are brush chain grabbers for the smaller clumped stuff.
If repeated, bush hog work will kill the offending trash vegetation, that's the easiest route. If you have specimens that are too large to cut with a mower, or on a slope or too near the water or marsh, jerk them out by the roots with an appropriately sized brush grubber at the end of a chain or pull rope. Your FEL bucket will be useful in uprooting vines and pushing them into a movable pile.
Poison sprays were introduced for large scale crop weed problems and are now being marketed for everything including Dandelion in your Kentucky Blue Grass. Avoid them if you can. The latest and greatest are increasingly implicated in mass killing of honey bee populations. (Hard hat donned for expected response from solve all problems from the better living through chemistry faction) Look up neonicotinoids and coumaphos. These are pesticides but also take a look at Monsanto's Glyphosate (N-(phosphonomethyl)glycine), a herbicide for evaluation of risk. Monsanto conveniently also genetically modifies food crops to be safe from Glyphosate killing.
You are gifted with a piece of land and you want to improve it. Kudos to you. There is no better solution than sweat labor and elbow grease. You and your JD should be up to the task!
/ Brush Removal Strategy #5
1026R owner,
Is your property fenced? If so, goats are the solution, especially if you have mutaflora rose. Bush hogging it cuts it down, but it is back in no time. Goats prefer the new growth and will keep eating it until it is gone for good. All the mechanical and chemical choices are not long term, goats are. They will clean and clear all of your property better and far cheaper and keep it clear.
/ Brush Removal Strategy #6
You're describing similar to what I have on the edge of a lake. Thorns, vines, brush. I use a handheld cutter with a rotating blade that looks like a circular saw. I start up high and then move down towards the ground basically cutting it into small bits as I go. The result is pretty good as its mulched in place. It does grow back, so I cut every couple of years. One thing to be aware of is that lots of surprises can hide in that type of terrain, including big rocks, holes and stumps. I found plenty of all and would have had a seriout issue if I were using the tractor.
You didn't describe the terrain, that factors in. If its flat then a tractor could get at it, if its steep or wet then on foot would be better. Tractor implements you could consider would be a sickle mower or brush hog, I think you'd get very tired with a BH and would be better with a FEL or ratchet rake to uproot the smaller stuff.
When i cleared a section I cut it by hand then used the FEL to pop out small stumps. You could also do roundup, then cut it down and replant without having to dig up anything...
/ Brush Removal Strategy #7
Almost everybody can use an inexpensive set of pallet forks.
I found the clamp on pallet forks worked well for tearing brush and vines out.
As you can see to the sides of the tractor there were thick vines and brush.
Push in, rip up
pile
My M4700 was able to rip up vines about 2" in diameter. Before I got the pallet forks I had only planned on using them to pile the stuff. I was pleasantly surprised how well they worked ripping the stuff out of the ground.
/edit
http://www.tractorbynet.com/forums/kubota-buying-pricing/272368-pallet-forks-2.html#post3213749
/ Brush Removal Strategy #9
There is a an attachment point for pulling stuff. I think they call it a drawbar in my JD manual. You pull from a higher point and you significantly increase your risk of flipping the tractor. That roll over bar works better if it is up and locked and if you are wearing your seat belt so you do not get tossed and crushed. That seat belt also keeps you in your place if you run in a stump hole or over a rock you did not see. I define a stump as what is left after I cut down a tree, not roots from brush. Heck they make root grubbers. Tractor Front End Loader Buckets Stump Bucket | Quality Welding Service
RecoveryHill mentioned a key point. You mow the stuff down and you keep it mowed down the roots may very well die off after a few years. If not you grub out the roots anyway you like.
Chunky tire sealant is your friend. At least for the front tires if you are running 3 rib tires. I am constantly puncturing tubes but the sealant seals up the holes. It saves me an hour of not having to remove the tube and patch.
I have used my trust or not so trusty Stihl with a brush cutter blade. It works well. I got some carbide blades that I have not used yet as the plain steel hand file blades seem to dull quickly.
I just drive my tractor into brush like you are describing with my blade low to the ground. It pushes stuff over and what it does not push over it has pushed out of the way enough that I can get in with a chainsaw, loppers, brush cutter or other weapon of choice.
/ Brush Removal Strategy #10
I bought a used DR brush cutter a few years back.....great machine and will do the job for you. New ones are pricey so another alternative is buy a Piranha Tooth Bar. I bought one of these a few months back for digging but was really impressed with it's ability to clear blackberry bushes. Great product! See below.....
BXpanded Piranha Tooth Bar
/ Brush Removal Strategy #11
1026R owner,
I agree with wolftree here - fence it, and toss in goats. Ours have done an awesome job of clearing property around here.
/ Brush Removal Strategy #12
I spent yesterday afternoon clearing out pesky native vines on 1/3 acre in Florida with 52" Ratchet Rake on the bucket.
The Ratchet Rake is not a ROOT RAKE but it does pretty well pulling out dormant vines by the roots, especially after a rain.
The Ratchet Rake is not a LANDSCAPE RAKE but it does pretty well raking/piling vines after they are pulled.
At $299 the Ratchet Rake is hard to beat.
After I piled the vines, I picked up the three piles one-at-a-time with 2,000 pound capacity Payne's aluminum Debris Forks. To load debris forks I pushed each pile against a tree used as a backstop. Picked up 20% dirt along with 80% vegetation but I did not have to get off the tractor. (Remaining on tractor is a safety issue. Always a small chance a hydraulic line will let go under max load.)
Each pile was 800+ pounds as I could barely lift them
I had 600 pound Howse disc harrow as ballast in the 3-Pt. lift or the front end would have gone down instead of the load up. Ballast behind rear axle reduced stress on the front axle.
Because of "danglers" I transported loads in reverse to the burn pile.
One or two passes with 48" King Kutter Rotary Mower (bush hog) in a few weeks should complete demise of the vines and scrub oak volunteers.
An enjoyable, productive day.
If you are using your chainsaw a lot consider purchase of 28V battery powered, reciprocating Milwaukee Sawzall. For anything up to 2" the sawzall is faster, blades are cheap and SAWZALL IS A LOT SAFER. If you acquire a PTO chipper you will use the Sawzall to trim branches before chipping; instant on/off is very convenient.
http://www.amazon.com/Milwaukee-071...-7&keywords=28-volt+battery+Milwaukee+Sawzall
I know nothing about GOATS but I like the idea in principle. Can your rent goats?
/ Brush Removal Strategy #13
I know you said you did not want to spray but if you have something that is large enough to use a chainsaw, or even a large pruners, pour a little Tordon around the edge of the stump to kill the roots. You do not have to coat the stump, just the outside edge. It is cheap and even though it is a chemical, local application like this does not contaminate things and you will not have to re-cut. You need to apply the Tordon very soon after cutting - like 5 minutes or so. you can buy Tordon at local farm store in a quart sized squeeze bottle with pop up squirt cap so it is easy to apply.
/ Brush Removal Strategy #14
I've done very similar clearing of overgrown pastures and used a variety of implements. DR brush mower is great for smaller areas but gives you quite a workout manhandling it through rough terrain or more than an acre or so. Bush hog is easy but not so useful in wooded areas or when trying to be selective. Ratchet rake works nicely in small areas and can be very selective but doesn't work efficiently in large areas. Flail mowers can be offset which helps get close to trees and fences. AgriSupply sells the very popular Caroni TM1900 for much less than what JD or others charge. For Escape sized bushes, nothing beats a grapple and strong loader.
I use all of the tools mentioned in addition to chainsaw and trimmer. Each has pros and cons. For a large area I usually mount flail and grapple. For smaller areas DR mower or ratchet rake.
/ Brush Removal Strategy #15
Our DR is not for sale but it can be a man beater. :)
We have some property lines a tractor cannot go. It is great to use the DR every couple years.
/ Brush Removal Strategy #16
Yea.....I agree...the DR is a workout....I do our perimeter (about 4 acres) every year. Blackberry bushes are like weeds here.....the DR helps maintain them. :thumbsup:
We do like the idea of goats and my wife and I talked about goats before posting the question here. But it's not fenced, we have construction going on, we're raising 29 chicks, adding a puppy, and taking on another critter right now might be system overload.
I was out there shoving on it just now with the front-end loader, so I can see where a ratchet rake or Piranha would be a great tool. After looking at it again, there may be too much of it around trees and rocks and uneven terrain to use a DR Brush Mower, especially the tow-behind kind. I'm back to thinking brush cutter and poison. A mix of measures might be the ticket. I'd like to have one of those brush mowers but hate to drop $3K right now. May end up with one, though, as a tow-behind mower would be nice for heavy stuff. Is the DR considered a flail mower?
/ Brush Removal Strategy #18
i would look at a used brush hog $600-800 range 4' probably for your 1026 - 5' likely a bit big.
The reason for used is you have rocks and stuff so getting one used you wont feel so bad clipping a few rocks.
Also you can raise it up and back over brush cutting it down to size.
The DR is not a flail mower, but the flail mower is decent around rocks, but wont knock down heavier brush like a bush hog.
Here's one used John Deere 1050 4x4 tractor loader back hoe in NJ..
I have a Gravely Super 8 with 30" brush cutter that I might be will to part with but 300 miles may be a bit of a hike.. and a lot of work to run in your conditions - it wouldnt get the big stuff but would work on smaller vines and underbrush.
Carl
/ Brush Removal Strategy #19
The model of handheld I use is a shindaiwa T2510 with a 12" saw blade attachment. Its about as heavy as a weed wacker, but has a ton of torque and runs at a lower RPM so it's pretty quiet. It is excellent with vines because you can swing it around. The handheld is better for working close to trees rocks and drop offs than something that is wheel powered. I think the total cost is about $250 or $300, but there are definitely cheaper models out there.
/ Brush Removal Strategy #20
1026R owner,
Keep the idea of goats in the back of your mind then. They will do a better job than any mechanical or chemical device. The seed from upwind will always be landing on your property and goats will be there to eat the new growth. Given enough time and goats, they will turn any woods into a park and keep it that way.
I had places I was afraid to back a bush hog into, never knowing if there were rocks or a 47 Plymouth bumper hidden in there. The goats cleared it out and kept it that way.
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2019 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 MACK ANTHEM...
207279 (A52708)
207279 (A52708)
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
John Deere 1023E (A62177)
John Deere 1023E...
2015 Teupen TL54J Crawler Articulating Boom Lift (A61572)
2015 Teupen TL54J...
