Buying Advice 54 Inch Fine Cut MMM
/ 54 Inch Fine Cut MMM #1
Byrdnyrd
Plymouth MA (where they burned the Witches)
BX2370 60" MMM with bagger, BX5450 Front mount Blower, soft cab, 48" Brush hog, Several Gravely's, Lots of Land Rovers, Best wife EVER!!
Hi all,
Quick question: can someone tell me the Model Number of the 54" FINE CUT mid mount mower.
I want to be sure I order the correct number. The model numbers are not listed in the BX brochure.
Thank you!
BN
Never mind! I found it!
If you "Build My Kubota" and hit "Print Quote" it lists the part numbers
For the record the part number for the 54" FINE CUT mower is: RCK54P23BX-54
Cheers,
BN
/ 54 Inch Fine Cut MMM #3
I had a reg 54" MMM on my Bx2360 and have since got a new Bx2670 and went with the 60" MMM. A lot of members suggested the 60" and after seeing the difference ( not in cut but 5' is WIDE ) I wish I would have gone with it in the first place.Just a thought to pass along before you commit to a 54".Maybe a $200.00 difference.:2cents::cool2:
BX,
My property has a lot of trees on its not exactly flat. I like the idea of the smaller mower and everyone seems to think the Fine Cut deck works well.
Thanks for the input! I love this forum!!
BN
/ 54 Inch Fine Cut MMM #5
Just remember that the 60 inch deck sticks out on the left side more and you have a smaller uncut radius when going around trees, so I would look at the 60 very hard. The 60 inch deck has a balancer bar that equalizes side to side that also helps in uneven ground.
David Kb7uns
/ 54 Inch Fine Cut MMM #6
My normal recommendation is the smallest tractor and the widest deck you can fit between the narrowest points you have to drive between. The larger overhang is a plus too!
/ 54 Inch Fine Cut MMM #7
I went through this a few years ago when buying my 2660. I, too, was going for the 54. The ability to get closer to ditches, trees and fences and have more clearance to the tires actually makes the 60 pretty good. I'm happy I went for it and was happy I followed these guys advise. One thing I've done is put a 1/4" eye-bolt with a rope thru the eye and thru the rubber outlet skirt. If I need to I can just pull it up to get inside obstructions.
/ 54 Inch Fine Cut MMM #8
I must be in the minority here.I prefer the 54 inch deck due to parts of my yard being uneven,I figure the smaller deck will follow the land better and not dig in as much.As far as fine cut verses regular cut,I have had both and don't see much difference between them.The fine cut is supposed to make smaller clippings but I never really measured them :laughing:
/ 54 Inch Fine Cut MMM #10
The overhang is definitely a good thing but the 54 inch on my BX2360 will mow as close as possible to an object without any other part of the tractor hitting the object.
/ 54 Inch Fine Cut MMM #11
How do you like your new machine? I'm curious how well it mows grass... being that you're in NC I'm sure you are already mowing. :laughing:
/ 54 Inch Fine Cut MMM #12
I have the 54 fine cut.
Its not that great of a mower.
/ 54 Inch Fine Cut MMM #13
I've mowed twice and am very happy with the cut,also going to the 60" I can mow the whole yard in about 2 hrs ,I was mowing 2 1/2 hrs before.:cool2::drink::cool2:
/ 54 Inch Fine Cut MMM #14
Great to hear!
/ 54 Inch Fine Cut MMM #15
I am going through the 54 vs 60" decision currently as well. This thread has been very helpful. Does anyone run a mulching kit on the 60"?
/ 54 Inch Fine Cut MMM #16
Cutting grass? It is snowing here today. I went with the 60 inch also mainly to speed cutting time. One of the best features is I can pull up to a tree with the overhang of the deck and eliminate trimming time.
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
Ingersoll Rand Air Compressor (A61166)
Ingersoll Rand Air...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
(4) Tex Star 205/75D/15 Tires and Rims (A64047)
(4) Tex Star...
Bomag Roller (A63118)
2019 CATERPILLAR 289D SKID STEER (A62129)
2019 CATERPILLAR...
