L5740 or wait for L6060?
/ L5740 or wait for L6060? #21
Brakes on the left?
I haven't seen one, but I am pretty sure it was posted in one of the threads; may be wrong though, if so my apologies. I know the BX25D now has the brake on the left.
/ L5740 or wait for L6060? #23
TripleR I believe you are correct the brake pedal has been moved to the left hand side where the clutch was. This could get confusing or difficult to use if you have a weak left leg
/ L5740 or wait for L6060? #24
I know I am on the wrong forum, but I would like to throw my 2 cents in here.. I got used to the brakes on the left in about a day of use on my Kioti. No clutch, brakes on the left and 2 pedal hydro.. I am an old guy that hates change as much as the next guy, but I adapted to these changes really quickly. The brakes on the left of course allows you to use turning brakes. I hardly ever use them, but they can be handy once in a while.
James K0UA
/ L5740 or wait for L6060? #25
That is pretty much my situation, for years I had to use my right leg to operate the clutch on our tractors and had to quit using those without a flat floor. I realize my situation is unique and as many will have a weak right leg as right, so is moot over all. It was however a major deciding factor for me.
James K0UA
James, I have no doubt many can adapt and operate a tractor with left foot brakes. Every tractor we own with the exception of our John Deere has them on the right and I routinely get off our M8540 and onto our L5740 and some years ago I had one of those "OH S***" and instinctively hitting the "right" brake pedal on our M8540 kept me out of our pond at a pretty deep spot. I didn't have time to stomp on air then regroup and hit the brakes on the other side.
Certainly nothing wrong with brakes on the left as they are in the majority, I just don't wan them and said this for years. When I got my L5740 I experimented with the cruise control and steering brakes which are very easy to use, with my tires and ground brakes have little effect on the turning radius; traction control in snow etc and in reverse, brakes on the left seem to work better. A moot point anyway since I am definitely in the minority on this.
James, there is no "right" or "wrong" forum when sharing knowledge as far as I am concerned and your input is always helpful.
/ L5740 or wait for L6060? #26
I was hoping the 1055 loader would be a lot stronger than the 854 but it is not.
/ L5740 or wait for L6060? #27
James K0UA
Usable split brakes under modulated power [which means on the left w HST] can be handy for sure. OTOH, they can be essential when you find you cannot turn up that hill away from the fence with any other strategy. At that point they become "priceless". This, not totally confirmed at this point, change by kubota is great. My last holdout is for multispeed rear PTO option. I cannot justify premium $ without it in the 50+ HP range, and I buy used instead of new to get it on gear tractors ... even those of lower HP. When HST offers it I will buy.
larry
/ L5740 or wait for L6060? #28
They could have made it like the old Cub Cadets, 2 pedals on the left for split braking and 1 pedal on the right that applies both.
/ L5740 or wait for L6060? #29
I believe TYM also had that on some tractors and seems to be a good idea.
/ L5740 or wait for L6060? #30
larry
Just curious, what would you need a 1000rpm rear PTO for in that HP range? There's one implement here on the farm that can use 540 or 1000 and that's a Kuhn Disc Mower Conditioner and 60hp is the minimum for it.
/ L5740 or wait for L6060? #31
I noticed this too.
Interesting how the all new loaders are rated at less capacities (all around) than the older models.
The new dash looks good. I wish the L40s had that needle fuel gauge.
/ L5740 or wait for L6060? #32
I noticed this too.
The new dash is nice, I think the whole interior looks nicer than a L40.
/ L5740 or wait for L6060? #33
Yeah- the interior of the cab pretty much rocks! They look darn nice- going to be paying quite a bit more though. Still very happy I just bought my 4240 new- the "equivalent" 4060 actually loses a couple of horsepower...
/ L5740 or wait for L6060? #34
I've never had a tractor without a flat floor board so brakes on one side or the other never made a difference to me. My 580k has them in the center, maybe even a bit to the right but it also has a flat floor so I just move my feet as needed. But I don't operate the HST with my toe/ heel so there's more room on the right when moving forward. Once the local dealers start getting them I'm sure I'll check one out out of curiosity.
/ L5740 or wait for L6060? #35
Kind of hard for me to tell, but it looks like the lever cruise control has been replaced with one similar to that used in a car, if it has I much prefer the old lever type. I do really like the 4WD lever location, much easier to use.
I wonder if the L60 seat will fit in the L40; might be interested in that.
I grew up on tractors with the throttle on the steering column and prefer it, but our M8540 has the throttle like the L60, so it's not a big deal.
I would have to see one in person to see if the interior is "nicer".
/ L5740 or wait for L6060? #36
Are they just being rated differently,at a different point?It seems if they are measured the same then it would be another 200 kilograms,or about 445 pounds,of lift.That would be a fair amount of improvement.
/ L5740 or wait for L6060? #37
The specs I compared were the lift capacity at 500mm.
/ L5740 or wait for L6060? #38
I am due for a new tractor. My dealer had to do a bit of searching but found me one of the few remaining 5740's. I was afraid to get the new L6060 the first year of production. They look fairly complicated and I want them to work all the bugs out them before I get one. All the fancy electronics are nice when it works but when it does not work it can be a nightmare.
/ L5740 or wait for L6060? #39
PTO speed options on a 6 spline stub come in handy when you do a wide variety of different things. In the case of sprayer pumps its perfect as these accomodate higher speed fine and performance improves. 1000 is a a bit high for speed sensitive items cuz you have to run the tractor engine so much slower - it would be nice to have 750. Still, running a PTO gen at light steady load is a perfect opportunity to save fuel. Roto tillers thrive at a little above 540. !000 is workable here. 750 would be much better. Snow throwers as well.
,,,,You see people starting threads wanting a more appropriate speed for whatever theyre doing. The cost of an auxiliary gearbox is prohibitive, to say nothing of the logistics of using it. Tractors in the 20+ hp range used to have the option built in. Building it out didnt save much, but its now a limiting corner that has been allowed to form driven by the "economy" customer without the foresight given by wider experience.
larry
/ L5740 or wait for L6060? #40
Grand L60 brochure, got it from another thread:
http://www.toplinetrailers.com/documents/L60.pdf
Does anybody know for sure if this brochure is right? It talks about the new high pressure common rail fuel system but then in the specs shows an indirect injected engine. I'm confused because indirect injection and high pressure common rail in a medium speed diesel don't go together unless Kubota has something new. The high pressure common rail system should be for a direct injection multi-shot cleaner and more economical, although more expensive, engine. Could this spec sheet be wrong? See that Kubota still doesn't have the specs on their site.
Lot 1001 (A64047)
Lot 1001 (A64047)
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59909)
2019 FREIGHTLINER...
UNUSED RAYTREE REDM32-32" EXCAVATOR MULCHER (A62131)
UNUSED RAYTREE...
211298 (A62131)
211298 (A62131)
2021 John Deere 320R Loader (A63116)
2021 John Deere...
