Reverse the tread
/ Reverse the tread #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
I need to move some dirt down a hill a few feet to make a level spot for a shop and road behind my house. The hill is pretty steep and I have trouble backing up it. The ag tires pull fine going in the direction of the tread and I'm thinking that I might reverse them so I can push the dirt down hill with the loader and still be able to back up for the next push. Has anyone ever done this and if so, how well did it work?
/ Reverse the tread #2
I have no personal experence with reversing tires, but I have seen tractors with one tire reversed. I guess it was common practice working for in sand/ gravel pits years ago. You would use the steering brakes to give traction to the correct tire.
Bill
/ Reverse the tread
Thanks, Bill. There was a tractor for sale somewhere the other day with one reversed tread. You probably just explained why it was done.
/ Reverse the tread #4
I have seen the tires reversed on a old Farmall M that was used for pulling. The tread designed to help drop the dirt/mug out from between the lugs when going forward so reversing them will cause it drop the mud and get better traction in reverse.
When I see a tractor with one tire on backwards I have to think that the person installed the tire on the wrong way (dish in or out) and instead of dismounting it and changing the direction they left in on backwards.
/ Reverse the tread #5
I can't say it wouldn't help but the way I see it it's more about weight distribution. as soon at the tractor is headed down hill the weight on the drive tires shifts forward. and with most of the weight of a tractor foward of the drive wheels I don't think the tread direction would matter much. I would think you would have better luck putting ballast behind the rear wheels. That's just my two cents.
/ Reverse the tread #6
It worked well for me, I could really tell the difference. It is easy to do, just raise the back, support it securely, unfasten one wheel, roll it to the other side, unfasten that side roll it to the first side and fasten them on, That is it, reversed!
I had to do it on the front, but same result. I was working in some sloppy stuff!
/ Reverse the tread
John,
You're probably right about the ballast. I haven't had this tractor very long and don't yet have a ballast drum or a heavy implement to use for balast so, I thought I'd check out my options before getting down in the dirt tomorrow.
Xfaxman,
Thank you very much. There's nothing like experience!
1996 Champion 540P (A64126)
1996 Champion 540P...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
