Notched vs smooth disks
/ Notched vs smooth disks #1
Jordan9682
Southwest sk
New holland 9682
As far as atv discs go, do notched disks pulverize the soil more, or less than smooth disks?
Which require more power to pull?
/ Notched vs smooth disks #2
Notched discs cut/pulverize better.
But the greater issue is harrow weight bearing on each disc.
The general rule for adequate cutting with disc harrows is 40 pounds bearing on each disc.
ATV discs are usually just a fraction of that so do not expect too much.......
All disc harrows cut better after a good rain.
Notched and smooth discs pull the same.
So if you want to keep some structure to the soil (not complete powder) its best to use smooth blades after it is broken up?
/ Notched vs smooth disks #4
Don't use notched blades in stoney soils!
/ Notched vs smooth disks #5
i like notched blades with vegitation.. and smooth for leveling.
atv discs are toys pretty much..
/ Notched vs smooth disks #8
Notched discs are more prone to breakage or deforming than smooth discs when rocks are encountered, especially at speed.
I doubt this is much of an issue with ATV harrows, which are light, and likely to ride up and over rocks.
Its not like having a 2,500 pound disc harrow, traveling at speed, encountering a big chunk of granite.
/ Notched vs smooth disks #9
Trust me, this will not be an issue with any ATV harrow.
Tractor tandem harrows are frequently sold with all notched blades, or notched front + round/smooth rear; rarely with round + round.
Give yourself a chance. Buy your ATV harrow with notched blades.
T-B-N LINK:
http://www.tractorbynet.com/forums/attachments/275147-disc-harrow-primer-howse-disc.html
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
2015 Chrysler Town & Country Van (A61569)
2015 Chrysler Town...
1992 John Deere 210C 58HP Loader Utility Tractor with Box Blade (A61567)
1992 John Deere...
2014 Anderson Trailers T/A Tag A-Long Trailer (A61568)
2014 Anderson...
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
