Bandsaws---what type?
/ Bandsaws---what type?
Sounds like a Band saw is sweet for many things but slow. This is OK if you have other items to deal with while waiting? I would guess one could get used to doing things in this manner.
The cols saw looks to be fast but you have to get the right blade for long lasting quality results. There are a number of negative reviews on the blades on some of these saws but when they work, they are very good.
I guess, the lesson is that there is no one type of cutter for good all around needs. Many will do some things well and others not so much.
Now it looks like my budget will have to grow for all the right things in the shop?
Band saw-1000
Plasma cutter-900
Dry saw-450
multi process mig, tig stick welder-800
Spool gun for aluminum-250
Tank of argon-180
I have the Lincoln 251 mig for general steel needs.
Maybe 6000 in supplies and I am all set to do something?:)
I get the role saw info.. Makes sense but I do not need that cost and would not know what to pick up used if anything.
Gray
/ Bandsaws---what type? #22
I picked up a old (1985) Greenlee model 348 (which looks like this Telmac, i think greenlee actually bought them out years ago) at a local auction for $200. Cleaned it up and found some blades online and checked it for square and I'm set. It's a dry saw with 1hp and four speeds. The blade can be tilted left to 15, 22.5 30, and 45 deg. And you can pivot the fence to any angle you want so you can do compound cuts.
This is my saw below. Same saw just viewed from the other side.
So for,less than $300 I have a metal cutting bandsaw that will cut up to 8" pipe. Might not be new and shiney but it works just fine and for the amount of use I will give it it will go another 25 years I think which will be more than I need.
You can also disconnect the hydraulic ram which controls the cut speed and stand it up and with the opitonal table have a vertical saw (of sorts).
I'm looking for a copy of the operators manual if anyone has one. I have an active search on eBay but no hits so far.
/ Bandsaws---what type? #23
To respond to the question on Grizzly tools - I've used their woodworking machines (actually own several of them) and am assuming :)eek:) their metal working tools are equivalent. They are much much better than HF tools. They are made in Taiwan with US oversight. I would rate them in the middle as far a quality goes. For a homeowner, they are affordable and will last the homeowner's lifetime and are capable of better precision than most homeowners are capable of. I am aware of some commercial woodworking shops that use them as well. However, if I were a professional I would look at other brands if I were going to use it forever and needed lots of precision. Having said that, the owner of Grizzly says he uses their machines to make competition rifle barrels and has won several long distance matches - so, not sure what to think about the precision of the machines. The company does try very hard to keep their customers happy when a problem arises.
/ Bandsaws---what type? #24
Sounds like band saws are sweet for many things but slow.
Depends on what you are cutting and what saws you are choosing to compair.
Blade diameter is the limiting factor with a cold saw, blade length is with a band.
For instance, you could sit there and move a few sections of tubing with many operations and measure each cut with a manual cold saw for a long time to cut as much material as a good band saw can cut in one pass.
This one is not even half full and will cut and auto feed to the next cut quicker than you can debur and weld the first cut, in this example 1x1box tube, 20 cuts per one push of a button.
You would need a very, very large cold saw to make a cut like that.
TTR,
Thank you for your note. I have a great deal of woodworking experience withna few of their machines but none with their metal working machines. I was not aware of their ties to the factories and oversight. It may be in their cataluoges but it has been years sense I saw one, back when I was teaching woodworking and cabinetmaking.
Only recently I have found enjoyment in metal fabrication and am expanding my meager welding and cutting equipment. I have done a few small projects then applied my background in teaching " shop" to building a water well drilling rig and that has me looking at more challenges:).
I may retire for the second time and will need a hobby other than construction and this one keeps my attention.
Thanks again,
Gray
/ Bandsaws---what type? #26
My bandsaw is a 6x10 from Northern Tools that's pretty much the same saw as the Grizzly 6.5 x 9.5. Got it on sale a few years ago for less than $300. I get good service out of it. Stripped the lowest gear in the gearbox during the first year and they replaced the saw under warranty. That gear in the gearbox is pretty wimpy so now I normally run in the middle gear. Northern no longer carries that model. The 85" blade is harder to find than the blade for the 7x12 saws - I can still order them from Northern. The belt drive models are probably more reliable.
I would recommend a 7x12 if only because it's so much more common and you should always be able to find blades and parts.
Yes, gang cutting is a good thing if you have multipule production needs but I am for the most part a one off person. R and D things, special projects.
I do like the band saw as a quite and steady cool accurate machine, I was just trying to get a take on how fast it really cuts.
In woodworking you get used to speed:) It is tough to slow down even when one should.
I am leaning towards Grizzly or Enco? Not so sure of Jet even though some have said good things and they are running sales on them for a while at many outlets.
Gray
/ Bandsaws---what type? #28
If you are into one off, I promise that a roll in will be your best, most versatile friend. 1/8"-3/4" blades from 75 fpm to 500 fpm. It does the work of many different machines.
/ Bandsaws---what type? #29
Speed is having a machine matched to the job. Versatility is having a machine that can do many jobs.
Being a wood worker you can relate to the fact that a radial arm saw can cut 2x10's quick, a table saw can cut 10" off a 4x8 and a scroll saw can cut a 7/32" radius. A Roll In can do all of that in metal, not better than other tools but better than any ONE tool.
/ Bandsaws---what type? #30
One thing to remember with a bandsaw is you have to break a new blade in or it will wear out prematurely. Slow the feed rate to about half for the first few cuts. A good blade and the right coolant makes a big difference. If you break a blade, see if there's a bulk blade dealer in your area. They can be welded back together with a blade welder. Shops don't usually have blade welders because they can easily cost over $100,000.:shocked: I worked a few months at a blade distributor and welded lots of blades. They had a water cooled Ideal blade welder/annealer and blade grinder.
/ Bandsaws---what type? #31
Blade welders can be had pretty cheap from eBay and Craigslist up to 1/2" I have some blades that are 2 or 3 different blades with problem spots cut out of them and welded together.
Get the rite deal on an old band saw and they have one on them already.
/ Bandsaws---what type? #32
There are many saws which come with blade welders built in, and those saws are not $100k machines.
some fab shops I have worked in had Marvel vertical saws which had blade welders on them (but I don't remember if they were a Marvel accessory or something the shop added on) and I know those saws were under $100k new. We used them to cut 18" H beams and 12" tube steel on down.
They looked like this but earlier versions. I would love to have one of these if I had the space in my shop, even one 25 years old.
/ Bandsaws---what type? #33
A lot of commercial vertical bandsaws that are made for hand feeding material doing intricate shapes and stuff have a blade welder on them. A vertical structural saw that has power feed like the Marvel in your picture is a really expensive saw and doesn't have a blade welder. I've never seen a bandsaw designed for cutting structural steel that had a blade welder on it. A blade welder for those saws is very expensive. The blade welder I used would do from 1/4" blades up to 2" blades and was water cooled. 1/4" blades for wood working were the most troublesome to weld.
/ Bandsaws---what type? #34
This is a video of one of my automatic band saws running.
The idea is to multitask. So while it's cutting 100 of the box tube sections I sheared 182 pieces of angle at the same time. Thus doing the same amount of work as two guys or cutting time in half.
/ Bandsaws---what type? #35
I own a screamer Dewalt 12" abrasive cut off saw that found it's nitch in job site cutting of steel studs. Now seldoom used. Also owned an Atlas horizontal band saw, probably 6' x 8" capacity, 1/2" X 60" blade, better than a hack saw and slightly more acccurate than an acetylene torch.
The Mother Lode metal cutting saw I found is a 1940sh Kalamazoo 8" X 16" cast iron beauty that needed a lot of TLC. This machine is a dry cut but is dead nuts square on the money. There must stilll be a bunch of them out there as the Wilton Corporation still stocks a limited number of parts and I found replaceent bearings at Motion Industries. Need to whack off the end of an 8" I Beam, no problem, finding a few young bucks to carry said beam..........Good Luck
/ Bandsaws---what type? #36
I bought a new Ellis 1600 for $2100. I had an older model and just wanted a new piece for the shop. Incidently the old Ellis brought more money than What I paid for it. It is a dry saw that is extremely accurate.
/ Bandsaws---what type? #37
I still don't get exactly what the difference is between a "roll-in" saw and any other metal band saw. Google is no help.
/ Bandsaws---what type? #38
A roll in is different because it combines the offset blade of a horizontal (so you can cut any length) while still being a vertical band saw with a table for "hand work".
It is also self feeding using gravity, you adjust the counterbalance on the left side of the machine to set the cut pressure, clamp the work and let it go.
It can miter and the table is already drilled an tapped for stops, like the adjustable on I threw together.
I also added a switch to mine so it will turn off once it completes the cut. Lets me know when the part is ready for my attention again.
/ Bandsaws---what type? #39
IF only they weren't so expensive...
/ Bandsaws---what type? #40
No such thing as a free lunch.
2012 Ford Transit Connect Cargo Van (A66736)
2012 Ford Transit...
PORTA POTTY (A68842)
SDlanch SSL60 (A64912)
PALLET OF HOSES (A68842)
PALLET OF HOSES...
JLG SKYTRACK 6042 TELESCOPIC FORKLIFT (A65056)
JLG SKYTRACK 6042...
SARLO (A64557)
SARLO (A64557)
