Bandsaws---what type?
/ Bandsaws---what type? #1
yarg
UP of michigan
L48 Kubota
I have been looking at many options for cutting. I will get a dry cut saw, a plasma cutter but I have been also thinking of a band saw to round out all my needs. I have seen there are wet, dry, horizontal, vertical convertable and swivel head types.
I am sure I will need an 8" throat but now comes the value options.
Wet or dry?
Convertible would be nuke but is it that functional?
Horizontal for sure.
Not convinced a swivel head would be needed.
How fast do they cut?
Would it be a waist of time to get a dry cut if I get a nice band saw?
As always, more questions may come up but any information from those who have experience would be helpful.
Thanks,
Gray
/ Bandsaws---what type? #2
I have a Milwalkie porta-band, it's 30+ y.o. and works great for many cutting jobs but it sounds like you're talking about a stationary saw. Got one of them too and it is a great tool as well. I'd go with the "wet" saw, mine is not but I have no trouble just keeping the cut and guide wheels wet with some wd40 or the like. It does have a good 3" deep pan to add a coolant pump, but in 20 or so years, I just have not gotten around to it. As for the vertical, I would not bother, I have another saw (dedicated vertical) and just do not use it. I am not familiar with the "swevel head" feature. You might start with the porta-band saw first while your looking for a good deal on a nice commercial horiz machine.
/ Bandsaws---what type? #3
To digress for a second, I also have an ancient Milwaukee portaband, and it is the handiest of all the metal working tools that I have, next to my Evolution chop saw. I buy bands at Home Depot, where I can get two Milwaukee blades for less than one at Northern Tool. I love the thing. And, unless you are a total goober, you can cut very safely with it.
It would be a stationary one as that would be 99% of my work, in shop clean accurate cuts.
Vertical is not used much? If the unit, like a Jet I saw can convert to vertical, that may allow for the ocational odd shape?
Wet saw seamed to be the right choice. The only one I ever used was in our HS welding shop and was a wet type.
It seamed to cut very slow but maybe it was the saw,blade ,or settings?
More info the better.
Thanks ,
Gray
/ Bandsaws---what type? #5
Shield arc,
Do you know annoying about the Grizzly? It's a bit smaller but has the vertical option.
The enco is a belt change speed? Any more info on that one would appreciated as well.
Gray
/ Bandsaws---what type? #7
Never seen a Grizzly saw, I just added the link for a comparison. I do have a Grizzly Mil.
The ENCO saw will go vertical too. I always set my metal working tools to the slowest speed and leave them there.
/ Bandsaws---what type? #8
I don't know your budget but I saw a saw last week that will cut just about anything. It had a 2 1/2" blade and 43.3" capacity.:shocked: It was brand new but I didn't ask the price. :eek: A swivel head saw is great feature to have. If you have roller stands or even just saw horses to hold long lengths, you don't have to move your feed table when you do angle cuts. The swivel head also has the degrees marked for more accurate cuts and odd angles.
/ Bandsaws---what type? #9
Roller stands are only the start, you also need one of these.:D
/ Bandsaws---what type? #10
You need to look at Roll In saws.
What I know for sure is that my abrasive chop saw will not be my major cut off tool any more! After my first big project, I will not do that sny more.
If a band saw does all and more than a dry saw, I may put more into the band saw. I am concerned about speed, I am sure it would not be as fast as a dry saw?
About 1000 if both saws and up to 1400 if just a band saw?
Gray
/ Bandsaws---what type? #12
One thing nice about a bandsaw is you can start the cut and walk away. Not far away but away. I have a cheap Chinese bandsaw I got that is probably 25-28 years old. It does what I want which is cut metal without a lot of dust, sparks and noise. It is not quiet but it is less loud than an abrasive cut off saw. I would lust after a wet bandsaw if I were a fabricator but the dry one works for the occasional barn door build or other simple 20 cuts project. If I need to do a big project I drive off to my friend's shop that has bigger everything.
What is a roll in saw?
Just googles roll saw and know now.
I also looked at some reviews and they are not fond of the jet,dake.
The enco is ok? The grizzly I have not heard about?
Still no idea of speed vs a cold cut saw?
Can one do a lot mire than the other?
Gray
/ Bandsaws---what type? #15
80 tons SA? Just what the heck are you fabricating over there?
That was two spreader bars for setting precast concrete utility vaults for the Pier D aircraft carrier pier at PSNS. I had to cut and splice that beam so I could keep the decals in place. That crane is engineered for only 2-tons max.
Is this HF the same machine as the Enco? It looks very much alike.
If the motors, and contols are also the same then the HF sells for less.
Thanks for the heads up,
The Grizzly is about the same cost for a 6x9.5 with shipping. Anyone know about this machine?
Gray
/ Bandsaws---what type? #18
I somewhat figured, didn't look quite up to 80ton capability but I have to say you have all the cool toys!
Chris.
/ Bandsaws---what type? #19
Just googles roll saw and know now. I also looked at some reviews and they are not fond of the jet,dake.
The enco is ok? The grizzly I have not heard about? Still no idea of speed vs a cold cut saw? Can one do a lot mire than the other? Gray
A roll in is semiauto so you just set the feed rate with the counterbalance and gravity does the rest. I added a switch so it cuts off when finished with the cut.;
It has an offset blade like a horizontal so you can cut any length, unlike most vertical bandsaws.
Remove the clamp and miter part and you can use it just like a vertical bandsaw.
I have never used any other brand but did pick up my last one for $500 on Craigslist.
There is as much difference between "coldsaw" as there are between "bandsaw". You can get coldsaws that are just slower versions of the normal chopsaws (like the little dewalt) up to large 3ph full auto versions that cost $20k+. One thing cold saws have in common with each other are that the blades cost a lot more than bands.
/ Bandsaws---what type? #20
I finally got a small HF clone bandsaw. 4x6, I think. Used for $100.
It started throwing blades. I shimmed the rear rollers, and it seems to be ok now.
Now I wonder how I ever lived without it.
It cuts dry. It takes a couple of minutes for a cut, but I'm normally doing enough other things that I can wait.
There are a couple of carbide metal cutting chopsaws that look very sweet, but a bit expensive. But, no doubt they would be a useful cutting tool.
As far as the rollers, my saw came with a very cheap roller from HF... pretty junky, but certainly useful.
I picked up a couple of boat trailer bow & keel rollers from the local recycling store, and was going to make them into a roller as I was having lots of problems with the pipe that I was cutting earlier not staying put.
