Seized motor AC wd-45
/ Seized motor AC wd-45 #21
atf plus a solvent is a good unsticker. I unstuck some valves in my ford 4000 after they stuck and mad artwork out of some pus rods.
in my case.. atf and some acetone.. plus a lil diesel...
I am kinda hoping to have something to test the ATF and acetone on. Have been hearing a lot of good things about it. Not that I'm complaining the pb+kroil made it unseize so fast I didn't get to try.
I'm ready for Saturday. Would love to try to start the wd45 that was locked. (aim high right) painted carb for it tonight.
The cub hood/tank is in my driveway stinking to high heaven. No time to clean tank this week yet. Maybe tomorrow night I can start. Really dreading this tank.
/ Seized motor AC wd-45 #23
The ATF and acetone works great.....used it last week removing bolts from a 1954 crawler we're working on. Used ATF and Turpentine (ran out of acetone) today on a 6ft hinge that hadn't moved for years. Worked great.....give it a try. Good luck!:thumbsup:
/ Seized motor AC wd-45 #24
can't wait to see more of the wd.
I'd like to get on e one day... that and a crawler.. and.. :)
Put oil filter on wd45 filled with oil and mmo(wanted to try it) Put carb on and hooked it up. Cleaned fuel bowl and screen then flushed line. Tossed battery in and finally got to crank it over. Let if puke ATF out of cylinders, tossed plugs in, turned on key, rolled over, and no spark. Picked up new 6v coil, points, and condenser on the way home.
Last night I plugged cub tank and dumped a gal of laq thinner in it. Looked at it when I got home and it's coming along.
Starting to get impatient may return this afternoon. :D
/ Seized motor AC wd-45 #26
fun bringing them back ain't it!
keep the updates coming.
Forgot to add pulled hood and valve cover again. Everything looking good and oiling well.
It's fun, but I need to hear something run!
/ Seized motor AC wd-45 #29
even better when the top end is immediatly happy!
My chief mechanic making sure I did it right haha. I like all the AC parts that were on it.
Success! Empty parking spot never looked so good
Left Family easter stuff to sneak by and toss parts on. Was a bad condenser but it got a coil and points too. Blew my mind how fast it started when I reached in and pulled the starter mechanism. It was like it had been running and I shut it off hot! Smoked like a train and blew a ton of crap out the stack. It cleared up and my father in law hopped on smiling jamming gears like he was a little kid again. It was like an rusty orange comet flying around the place. His best estimate was 30 years since it last ran. He sold it to his step dad for money to build a house and start a family. My father in law's father originally owned it but died at a young age. This thing has been all over my wife's family, lots of happy people today. Great Easter!
Performance notes: I Should buy a lottery ticket because carb was dead on-no adjustments at all. Engine felt strong I am curious on compression numbers though. Cylinder 1 has a big exhaust leak that needs to be looked into. Lift didnt move linkage felt seized down far. Need to grease everything still. Will have to pull rear rim and weld a patch on due to bad valve stem. Other than that it's onto the cub and wide front wd45. Will post some pics of the wd45 now that it can get out in the light.
/ Seized motor AC wd-45 #33
good empty space! :)
Cub tank is making progress should be "ok" by Saturday. I have a ignorant eight hour waste of time safety class Saturday now so my window will be short. Attached a picture of a lacquer thinner can that was clean I just drained tank into it. The drain off was like 520 armaflex glue. Also a bad shot of inside of tank but I can see bottom.
Just in time for the weekend.
/ Seized motor AC wd-45 #36
Looking good, hope to hear some good news on the cub
/ Seized motor AC wd-45 #37
Tank looks great..!! What did you clean it with..??
It had two twenty four hour soaks in lacquer thinner to remove the gas tar layer. Yesterday I diluted muratic acid closely monitored, flushed with water, then flushed twice with baking soda and water. Last I flushed it with pb blaster to prevent rusting. It still has some rust flakes floating around which is next to impossible to get them all. So I made a jig to attach to the gas cap. Little bit of chain, JB weld and a smoke detector magnet i had laying around to help along the cleanup.
Can't stress it enough always wear your ppe when handling acid!
/ Seized motor AC wd-45 #40
I thought it looked like you had coated the tank on the inside. Nice clean up job. A 2 oz per gallon of Sea Foam mix in the new gas may help prevent rust and future build up.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2019 FREIGHTLINER...
2020 John Deere 333G High Flow Compact Track Loader Skid Steer (A59228)
2020 John Deere...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
TraxMax Stand-On Tracked Sod Installer (A59228)
TraxMax Stand-On...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
iDrive TDS-2010H...
