3RD function loader lines
/ 3RD function loader lines #1
jd670
Gold Member
Kentucky
John Deere 3320 - gator cx - JD 425
I thinking of adding the 3 function hydraulics to my 300cx loader. Where do the lines hook to to get hydraulic fluid? I don't have the diverter valve hookup, but I have the third scv in the rear. Do I run the lines to that? The parts break down from JD don't show where to hook to.
/ 3RD function loader lines #2
Yes, It goes to the rear. What you get is 2 hoses that get you to the connection point of the other 4 loader hose quick connects. You get another bracket that will accomodate 6 quick connects instead of 4.
Ok. Then its up to me to run hoses to the rear scv?
/ 3RD function loader lines #4
Yes. I bought mine when I bought my tractor, so the dealer did it, but it was just zip tied to the hydraulic hard lines that go back there. Running the lines on the loader itself will be more of a pain.
/ 3RD function loader lines #5
The loader lines and the 2 SCV connectors (for grapple hoses, etc.) are hard-lines and part of a kit with attachment clips and bolt's, etc.
AKfish
/ 3RD function loader lines #6
Yes, the lines go to the rear couplers for the 3rd SCV.
Here is what you get in the JD kit:
HYDRAULIC HOSES AND OIL TUBES - THIRD FUNCTION (300CX)
Cart key PART NO. PART NAME QTY SERIAL NO. 300 300X 300CX REMARKS
1 M42702 Snap Ring 2 X
2 AW32609 Line 2 X
3 W45635 Plug 1 X (A) (C)
...... Plug 1 X (B) (C) (ORD AW28043)
4 AW30147 Hydraulic Hose 2 X 3/4" X 1800 mm (70-3/4") X 17.4752"
5 W45608 Cap 1 X (A) (C)
...... Cap 1 X (B) (C) (ORD AW28043)
6 AR94522 Hydr.Quick Coupler Plug 2 X
7 W45609 Cap 1 X (A) (D)
W42991 Cap 1 X (A) (E)
...... Cap 1 X (B) (E) (ORD AW28043)
8 AW30239 Hose 2 X 3/4" X 2300MM (90-1/2") X 3/4"
9 W42411 Cap 1 X (A) (F)
10 R105388 Tie Band 4 X
11 W45634 Plug 1 X (A) (D)
...... Plug 1 X (B) (E) (ORD AW28043)
12A W45797 Bracket 1 X (SUB W52215)
12B W53059 Bracket 1 X (SUB FOR W52215)
13 LVA12997 Hyd. Quick-Connect Coupler 2 X (A) 3/8", (SUB FOR AM105466, THIS APPL)
LVA13231 Hyd. Quick-Connect Coupler 2 X (B) 1/2"
14 AW32982 Oil Line 1 X
15 AW32983 Oil Line 1 X
16 W44542 Block Clamp 1 X
17 W52153 Screw 2 X (SUB FOR 19M8040, THIS APPL)
18 M70728 Cap 1 X (F)
W53377 Cap 1 X (E) 1/4"
19 X4010-T6 Hydr.Quick Coupler Plug 1 X (SUB FOR AW32184)
20 32246 O-Ring 1 X
21 AM102487 Hyd. Quick-Connect Coupler 1 X
22 M85099 Plug 1 X (A) (F)
W53387 Plug 1 X (C) 1/4"
23 W50244 Hose Clamp 6 X
24 19M7286 Cap Screw 2 X M6 X 25
25 14M7272 Nut 2 X M6
26 R26448 O-Ring 2 X
27 T77613 O-Ring 4 X
28 AM105467 Hydr.Quick Coupler Plug 2 X (A)
AR94522 Hydr.Quick Coupler Plug 2 X (B)
29 R26375 O-Ring 6 X
30 19M7286 Cap Screw 2 X M6 X 25
31 14M7272 Nut 2 X M6
32 ...... Cap 1 X (B) (E) (ORD AW28043)
.. AW28043 Plug 1 X (G) (I) 1/2"
.. AW34729 Quick Coupler Kit 1 X (H) (J) 1/2"
(A) FOR MACHINES WITH 3/8" COUPLERS PRIOR TO 1NOV. 06(B) FOR MACHINES WITH 1/2" COUPLERS
(C) Orange(D) Blue(E) Green
(F) Black(G) Dust cap and plug(H) Coupler conversion
(I) Contains six colored caps and plugs(J) Contains AR94522 and 4 color dust caps
I see now. The lines that go under are roughly 5 feet long. They should reach to the back scv. Thanks guys for the help. I'll get the kit ordered.
I found a complete kit on ebay for a 400cx loader for $100.00. I crossed referenced the part numbers for a 300cx kit and the only thing I found to be different was the hose bracket and a couple of colored hose plugs. The kit was brand new. I went ahead and bought it. Should be here Monday.
/ 3RD function loader lines #9
Whoa...! That's a real score! Hope it's all there.
AKfish
Me too. From the pics he had posted it looked to be.
Got the kit today. It's brand new. The only thing that is missing is one of the metal oil lines. $39 from my dealer. The hose bracket is for a 400cx loader. I'm going to see if my dealer will switch to the 300cx one.3rd function (1).JPG3rd function (2).JPG3rd function (3).JPG3rd function (4).JPG All in all I think I did pretty good for $108.
Got kit installed yesterday. Picked up the oil line that was missing at my dealer. Everything went together good. I cut and rewelded the hose bracket to clear the loader mounting bolts instead of switching. 3rd function 001.JPG3rd function 002.JPG
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
UNUSED KJ 40'X20' STEEL CARPORT SHED (A62131)
UNUSED KJ 40'X20'...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
18' Utility Trailer (A64047)
18' Utility...
