CDP MID600 "backhoe build" project
/ CDP MID600 "backhoe build" project
WOW...hard to believe last post in early Feb.
progress pictures....
sub frame and main swing framework mounted to B7510
subframe and swing feamework
pic of swing connection to subframe
/ CDP MID600 "backhoe build" project #23
looking good don, I'll be watching for future posts.
got the stabilizers assembled, mocked up the arm and bucket.
after seeing the post...need to include a close up of the stablizer arms
OK, did some painting. first some rustolium metal primer applied via a cheapo HF spray gun..
worked pretty darn good! first time spraying paint in 30 years!
Got some bright Bota ORG from the Kubota dealer 3 miles from the house, only $35 paint for a Qt., 15 buck pint of solvent...not too bad for Kubota dealer?
Will post bota orange parts tomorrow.
Orange painted parts...
and a correction on the solvent cost...10 bucks
20130417_150229 sub frame orange paint on bucket.jpg 20130417_113028 bucket and booms orange.jpg
/ CDP MID600 "backhoe build" project #27
Very good job. I have a B7510 also, but with a Woods 6500 on it. Great combo since its also sub frame. Are you using tractor hydraulics? If so I would LOVE to see, in detail, your hydraulic hook up. Also a close up shot of the rear sub frame attachment. Again great work, looking for ward to seeing more.
Curtis
/ CDP MID600 "backhoe build" project #28
I have the CDP Mid 600 plan but either mine is an early model (it has a 2.5 OD box section dipper) or Ray has altered his to have boom & dipper of equal type box sections. If this is done do you have to alter the bucket curl linkage in any way from std. 2.5 box sectional dipper as on plan. The scheme uses a quite rare closed pin centers length cyl from 'Princess Auto' - also expensive. In my country there is now a very close metric equivalent from Flowfit / Harrier Fluid Power - this may make building this more practical for me (or others based in Europe). Sorry it is such an old post but there is little info re the CDP kit builds
CAT 930 60" Forks (A68134)
CAT 930 60" Forks...
PALLET OF 51 X 41 X16 BRASS WEAR RINGS (A67714)
PALLET OF 51 X 41...
2003 Johnson 50hp 4-Stroke Outboard Boat Motor. (A66738)
2003 Johnson 50hp...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2004 FRAC TANK 500BBL WHEELED (A68842)
2004 FRAC TANK...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
